speedyxjs
| posted on 13/12/09 at 02:12 PM |
Good news, more good news and hazard problem
Good news - My alternator is finally sending the right charge to the battery and i am getting 14.3v across the battery, yay.
More good news - i have nearly finished all the wiring for the car.
Hazard problem - I have connected my hazard switch as per this diagram:
[img]http://locostbuilders.co.uk/viewthread.php?action=attachment&tid=124276&pid=1039962[/img]
but i can get them to work. The relay clicks once when i flick the switch (halfords 3 pin hazard jobbie) but i get no lights. Indicators work fine
though. Any idea's what i have done wrong?
| posted on 13/12/09 at 02:40 PM |
so what was up with the alternator/wiring?
speedyxjs
| posted on 13/12/09 at 03:00 PM |
I had connected it to the wrong pin
I wired it the way you said when my plug came yesterday and it works!
RichardK
| posted on 13/12/09 at 05:02 PM |
Don't rule out a dodgy left hand stalk unit that includes the hazard assy if you're using sierra switch gear as they are a known weak
spot, I'm on my 2nd now. Tell tale is keep clicking the hazard switch with the indicators on and sometimes the indicators will fail to work,
continue to press the hazard switch and indicators start working again.
Rich
Gallery updated 11/01/2011
speedyxjs
| posted on 13/12/09 at 07:34 PM |
Rich
No, it all jag switch gear for the indicators
bi22le
| posted on 13/12/09 at 11:03 PM |
sounds silly but make sure your indicator is not on when using the hazard switch. Depending on switch hear age it may feed back and not work fully.
Just a thought.
Please read my ring story:
speedyxjs
| posted on 14/12/09 at 07:15 AM |
Indicator switch wasn't connected as it would only work indicating left
Have had to buy a new one on fleabay
