FrankP
| posted on 24/12/09 at 12:00 PM |
Acewell 3853 Wiring Query
I am trying to wire a Acewell 3853 and am stuck on the wires that go to the speed sensor.
Acording to the wiring diagram that I have the speed sensor wiring has a green and white wire that connect to to the red and white wire on the on the
speed sensor - however on the unt I cannot see an white wire - am I missing something - hoiw do I connect the speed sensor?
Frank
Alan M
| posted on 24/12/09 at 12:52 PM |
Isn't it one of the 2 pin plugs? Acewell electrics are faily robust so I don't think you'll blow the unit if you connect it up
wrong. I can have a look for you when I get home from work later.
russbost
| posted on 24/12/09 at 01:54 PM |
Should be a 2 pin plug connector, male/female halves - you shouldn't need to be connecting separate wires???
[Edited on 24/12/09 by russbost]
FrankP
| posted on 24/12/09 at 03:22 PM |
It would appear my unit is missing a sub loom assembly.
Thanks for all your help.
Frank
bigpig
| posted on 24/12/09 at 06:15 PM |
On the acewells you get a plug between the sensor and the unit, but the extension loom is an optional accessory (as usual), I just chopped the sensor
end of the wire and spliced in an extra meter or so of wire.
