speedyxjs
| posted on 24/12/09 at 08:34 PM |
One last stupid question for today
Should the horn work with the ignition off?
I have the horn on the indicator stalk but it only works when the ignition is on and the power is going to the indicators. I cant find anything in the
IVA manual (so you cant tell me the answer is in the quote )
blakep82
| posted on 24/12/09 at 08:41 PM |
hmm, i don't think it needs to. never needed to use the horn with the engine off, so i don't know how they normally work. in fact, mines
broke anyway lol
________________________
McLannahan
| posted on 24/12/09 at 08:42 PM |
Horn normally works without the ignition.
yellow melos
| posted on 24/12/09 at 10:27 PM |
go and try it on your tin top... if it works.. you will probably find it will need to for the IVA
cerbera
| posted on 24/12/09 at 11:23 PM |
Dont think my Golfs horn works with ignition off.
blakep82
| posted on 24/12/09 at 11:25 PM |
don't think mine did either ^
brake lights used to work with ignition off, they don't anymore
don't think you can flash main beam with the ignition off anymore either
[Edited on 24/12/09 by blakep82]
speedyxjs
| posted on 25/12/09 at 08:05 PM |
All tintops i have ever owned have had the horn work with ignition off but so has headlight flash. I cant find anything in the IVA manual to suggest
this is a requirement (h/l flash isnt even needed!)
