beaver34
posted on 25/12/09 at 08:26 PM |
colum stalks
hello, i have a sierra steering colum, and would like the standard stalks for full beam and indicators, is this possible? if so how do they fit i will
get some pics of the column i have ,
thanks
beaver34
posted on 25/12/09 at 08:28 PM |
i will get some better pics tomorrow,
thanks
doddy
posted on 25/12/09 at 09:06 PM |
the should be brackets on the colum part look like your have been cut off
[Edited on 25/12/09 by doddy]
beaver34
posted on 25/12/09 at 09:50 PM |
fair enough, rules that out then
Chippy
posted on 26/12/09 at 12:21 AM |
I think if you have a look at "Car Builder Solutions" they do an indicator stalk that clamps on to round tube, then you only need to sort
out some way of doing the lights. HTH Ray
ReMan
posted on 26/12/09 at 09:29 AM |
But unless you have another motive for using a "bare" column just get another, complete with switchgaerf and steering lock for £20ish
beaver34
posted on 26/12/09 at 10:52 AM |
its got the wheel adaptor welded to the end of it, ill see
gavin174
posted on 26/12/09 at 11:39 AM |
you only need to change the outer part of the column.
sometimes come up on ebay.
you can retain your modified shaft.
beaver34
posted on 26/12/09 at 12:30 PM |
ahh ill have a look then,
thanks alot
