Author: Subject: Oil Pressure Light Wiring Query.
FrankP
posted on 26/12/09 at 06:01 PM Reply With Quote
On my new acewell there is an option to have ab oil pressure warnig light with one wire.
On my loom the oil pressure light I have on my loom I have 2 wires connecting to the oil light. - I am assuming one is just an earth? and one is the 12v feed.
So would I be right is assuming that I can connect the 12v fed to the light on the acewell and isolate the other wire as its only an earth.
Does this make sense or am I missing something?
Frank
posted on 26/12/09 at 11:46 PM Reply With Quote
The oil pressure switch is what does the grounding, so the lamp will need an ignition switched +ve supply on one side, and be grounded via the pressure switch on the other.
