tomgregory2000
posted on 26/12/09 at 07:18 PM |
Fuel return line?
Am i right in thinking that the return line can be normal low pressure fuel line?
scudderfish
posted on 26/12/09 at 07:20 PM |
Yes
antonio
posted on 26/12/09 at 07:34 PM |
as above
A1
posted on 26/12/09 at 07:58 PM |
its what i use
posted on 26/12/09 at 08:00 PM |
8mm copper pipe. Saves you having to replace the rubber hose when it perishes.
[Edited on 26/12/09 by coozer]
tomgregory2000
posted on 26/12/09 at 08:41 PM |
Thanks guys
I thought it would be ok
Its to connect to the copper pipe
turbodisplay
posted on 27/12/09 at 09:35 AM |
I would treat it as high pressure line as if the end gets blocked, it will be now at high pressure.
Also high pressure stuff is more resistant as it is thicker.
Darren
aitch
posted on 27/12/09 at 09:52 AM |
Darren
this seems sensible, and very little additional cost to do it this way
belt and braces
aitch![](/images//smilies/cool.gif)
