speedyxjs
| posted on 29/12/09 at 07:46 PM |
Tidying wiring
Now that my wiring is pretty much done, what is best to use to tidy it up and secure it to the chassis?
| posted on 29/12/09 at 07:52 PM |
Split flexible conduit and cable ties.
For flat surfaces use these or similar
http://www.maplin.co.uk/Module.aspx?ModuleNo=6235
They stick on but I wouldadvise using a screw or rivet through the centre hole.
[Edited on 29/12/09 by britishtrident]
designer
| posted on 29/12/09 at 07:59 PM |
Agree, never stick on, mounts with holes are available.
gottabedone
| posted on 29/12/09 at 08:01 PM |
from what I remember, these ^^^ must be screwed on. They're great, I've used them and the split conduit on all of my cars. Some black
insulating tape on the ends or where you pull a cable out from the conduit makes a nice job.
dhutch
Semi adhesive loom tape?
- The westfeilds loom appears to be taped in boggo black insulating tape. Cable tied to chassis (ties around chassis members)
Daniel
speedyxjs
| posted on 29/12/09 at 08:06 PM |
Stupid question, how do you screw into steel?
r1_pete
| posted on 29/12/09 at 08:13 PM |
Self tapping screws, or you could use rivets, but, you have no control over the tightness and they can split the plastic.
speedyxjs
| posted on 29/12/09 at 08:15 PM |
I know self tappers (would prefer to use them) do i just need to drill a small hole to screw them in?
sorry for the stupid questions but iv always thought they would be too weak for steel.
| posted on 29/12/09 at 09:06 PM |
self tapping screw would do it.
you need to get right size drill for them and buy decent screws - i.e. selftappers NOT from screwfix.
wilkingj
| posted on 29/12/09 at 09:30 PM |
Use Loom tape. Not adhesive tape... as the glue goes all gooey after a while, and makes it all very messy.
Use the right stuff for the right job.
It makes a much better job all round.
Best Regards
Geoff
http://www.v8viento.co.uk
austin man
| posted on 29/12/09 at 09:44 PM |
use steel cutting screws saves drilling then screwing in. A decent battery drill / screwdriver or air drill will drew them in easily.
| posted on 29/12/09 at 10:16 PM |
Those stick-on pads very nearly cost me an SVA fail! Fortunately, all but a few had been riveted to the chassis (but I had to prove it).
Only a few weren't, so he allowed me some time to tie-wrap the loom to some convenient metalwork.
The moral of this story is - rivet or screw the mounts to the chassis!
MakeEverything
| posted on 30/12/09 at 12:11 AM |
Rivnuts.
Ive used these on the car, and they are fantastic.
When its done i plan to use Rivnuts to provide mounts for a "Boot Rack" so that i can stick a tent and sleeping bag on it and disappear
for a weekend.
Kindest Regards,
Richard.
scutter
| posted on 30/12/09 at 01:25 PM |
Just a tip, if your looking for larger sizes of convoluted tubing, nip down the garden centre, the stuff they use for fish pond plumbing goes to over
1.5" and is a lot cheaper than CBS, you just have to run a craft knife along it.
ATB Dan.
| posted on 30/12/09 at 02:02 PM |
Ebay sellers are cheap for split conduit.
