Gergely
| posted on 4/1/10 at 01:08 PM |
Savage switch problems - LEDs flickering
Hi, I wonder if anyone had the same experience: The savage switches we have iun our car don't light up sometimes when they should, only after we
have pressed and moved them a bit before. Then the connection inside seems to work again... It is the same with 2-3 of the switches and it was the
case already when out of the box and tried outside of the car. What can be done to help this? Any ideas?
Thanks!
Gergely
Our build pictures
nib1980
| posted on 4/1/10 at 01:12 PM |
yep i have the same, i put it down to a loose connection , checked everthing on the back and it seems to be fine now
corrado vr6
| posted on 4/1/10 at 01:36 PM |
Dodgy earth?
http://r1indy7.wordpress.com/
bassett
| posted on 4/1/10 at 01:49 PM |
I have some quite cheap maplin connectors as there in a stupid size and a wiggle usually helps but i dont think the build quality is great on them. If
its almsot permanent maybe a blob of solder will help. One of ours was sent back as it was the switch at fault though.
omega 24 v6
| posted on 4/1/10 at 02:35 PM |
bulb/led slack inside switch. This is what we usually find with the square variation of this switch in the workshop.
