Author: Subject: side repeaters on wings ?
big_wasa
posted on 4/1/10 at 07:30 PM Reply With Quote
I had half a kitcar mag droped on the door step saturday
I had a flick through and there was an artical on a gbs zero going throught iva.
It made comment on how 7's now had to have the repeaters on the front wings.
Any one know if this is correct ?
Nash
posted on 4/1/10 at 07:54 PM Reply With Quote
Did it actually state the front wings?
I was going to buy some wing mirrors with repeaters built in from CBS as a solutio to side repeaters!
I really don't want them on the front wings!
Build It, Buy It, Drive It:
Southern Kit Car Club
DavidW
posted on 4/1/10 at 08:03 PM Reply With Quote
I've been trying to work this out over the last few days and think that you do have to have them on the front wings.
A couple of people on here have found that the relaxation of the SVA rules which allowed them to go in the side panel has been dropped for the IVA.
Caterham put them there and the newly registered westfield in this months evo mag has them there too.
These seem to be what they use which look pretty grim.
I'd be interested to hear what anybody else has worked out.
big_wasa
posted on 4/1/10 at 08:30 PM Reply With Quote
This is what gbs are using and selling.
link
Breaker
posted on 4/1/10 at 08:34 PM Reply With Quote
I think the mirrors with side repeaters built in will look great. Or you can stick them (side repeaters) to the front bar of your roll cage.
I just bought a MK Indy R with full roll cage but I also haven't decided were to put the repeaters...
[Edited on 4/1/10 by Breaker]
bodger
posted on 4/1/10 at 11:20 PM Reply With Quote
Looking at the mirrors on the CBS website, they look great but I can't see how they'll meet the rear visibility requirements. Seems the only way to do that with the rear arches of a 7 is to mount them on the side of the front cycle wings.
skodaman
posted on 5/1/10 at 04:11 AM Reply With Quote
Crap. I just took off my old Mondeo repeaters to put on side of Locost.
Don't see how I can mount these on cycle wings. It's not like sevens have conventional wings to mount repeaters on.
Skodaman
russbost
posted on 5/1/10 at 08:30 AM Reply With Quote
You could surely sikaflex an "L" shaped bracket to the underside of the cycle wing & fit them to that?
blakep82
posted on 5/1/10 at 11:23 AM Reply With Quote
anyone checked the manual?
________________________
iank
posted on 5/1/10 at 11:45 AM Reply With Quote
Just read it
There seem to be two reasons for putting the repeater on the cycle wing.
1. angles of visibility being blocked by the rear arch.
2. They must be within 400mm of the edge of the vehicle. The scuttle/cage is likely to be a bit further than that on many cars, especially those with wide arch sierra width back ends.
Putting them on the wing mirror would seem likely to be a good solution assuming angles of visibility are ok.
As always check the manual/call your local VOSA test station to confirm if you are going for a first time pass.
Anonymous
Steve @ sVc
posted on 8/1/10 at 05:30 PM Reply With Quote
You must make sure that the wiring does not get “attacked” by the front tyre, and the angle of visibility that is required, is maintained – even on full lock. We have had customers buy repeaters to fit to the body after test failure because of this.
Regards Steve @ sVc
Nash
posted on 8/1/10 at 07:52 PM Reply With Quote
Having done a bit of research while burried in my house because of snow I see no reason why you can't fit LED repeaters to the side / edge of the wing mirrors as long as they face front and rear
I think a call to VOSA next week is in order.
I shall report back.
.......Neil
DavidW
posted on 11/1/10 at 11:11 PM Reply With Quote
Any update?
Nash
posted on 13/1/10 at 02:49 PM Reply With Quote
Side Repeaters for IVA UPDATE from VOSA
Just got off the phone with VOSA and had a very informative conversation with Mark from Technical Support.
The rule is that the indicator repeater must be within an "Angle of Visability" of between 5 degrees and 60 degrees from the rear of the car. These details can be found in Section 20 Installation of Lights in the IVA manual.
Also note the minimum dimension from the side of the car rule does not apply to repeaters.
He loves the idea of having them integrated into the rear view mirrors and sees this as a very good solution.
I did find onthe interweb an american commpany that sells LEDs for the side mirrors but they are mucho expensive and didn't look very good.
So I for one am going to go the LED repeater in the wing mirror route.
Hope that helps good people.
.........Neil
[Edited on 13/1/10 by Nash]
Macbeast
posted on 14/1/10 at 09:26 AM Reply With Quote
Hmmm...
I suppose it depends what height the view is taken from. These might pass ...
23 months in
23 months in
But why do they need to see the side repeaters from the back of the car when they can see the rear indicator lights ??
[Edited on 14/1/10 by Macbeast]
DavidW
posted on 24/1/10 at 10:20 PM Reply With Quote
I've just done this.
Image deleted by owner
Could be worse I reckon?
dnmalc
posted on 31/5/10 at 06:51 PM Reply With Quote
Has any one considered mounting them in the back of the headlamps this would seem to meet the angle of visibility and put them within 400mm of the edge if this is required.
sebastiaan
posted on 31/5/10 at 07:53 PM Reply With Quote
Isn't this a possible solution? If it's good enough for Donkervoort....
eddie99
posted on 31/5/10 at 07:55 PM Reply With Quote
Gavin174 passed his IVA a few days ago with his repeaters on the back of the headlamp unit.
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
PeteS2k
posted on 31/5/10 at 10:54 PM Reply With Quote
That's what I did on mine...
Not the best photo to show it, but you get the idea. I went this route largely because of the very thin front cycle wings on the Rush. I was going to make them temporary, but thought they looked ok in the end.
The watch-point on this approach is they need to be no more than 2600mm from the front of the vehicle.
stevegough
posted on 5/6/10 at 09:15 PM Reply With Quote
just looked at these mirrors with repeaters - don't think IVA guys will be impressed as they face forward (as far as I can make out). As the other guys on here have said, 5deg to 60deg is the required visibility from the rear - and you must be able to see at least half of the 'effective area' of the repeater.
Shame, but - there you go.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
Nash
posted on 6/6/10 at 10:15 AM Reply With Quote
Well, I ended up with the repeaters on the front wings! As mine failed the first time with them on he scuttle. passed now with cycle wing outside edge position.
IVA examiner actually said the scuttle was a neatr solution but not visable from 5 degrees below at rear due to rear arch.
Note, the VOSA guidence notes the examiner uses states must be visable +/- 420mm from repeater position. This means 420mm down which in effect means you need to ne able to see it from about 6 inches (150mm ) off the ground from the rear. This means the repeater in effect has to be on the outside edge of the car or very high.
.................Neil
G.I Ginge
posted on 11/9/14 at 08:07 AM Reply With Quote
My GTS Panther is just in for its first MOT. It does NOT have side repeaters- just front and rears, and yet it has clearly passed its IVA as I can tax it and it's in the DVLA database. How can this be? Am I somehow exempt from this requirement? The car is registered on a 61 plate, but was given a Q plate before that. Would that impact anything?
