Author: Subject: Rear disks....weight!
Triggerhappy
posted on 7/1/10 at 04:32 PM Reply With Quote
On my MNR Vortx i have Sierra 4x4 solid rear disks.....is there any lighter but still "dependable" disks out there?
The weight of my current disks just make my eyes wet....
Im from Sweden, so im escused...The Muppet drummer for president!!
Steve G
posted on 7/1/10 at 04:35 PM Reply With Quote
You're using the 4x4 rear callipers too?? Might be worth considering looking at this as a combination and swapping both.
Whats the budget??
Triggerhappy
posted on 7/1/10 at 04:46 PM Reply With Quote
Whats the budget??
I´ll use the ford rear calipers until car is thru all registrations...later im open to hydraulic parking brake and lighter calipers...
posted on 7/1/10 at 04:59 PM Reply With Quote
Hydraulic parking brakes are banned for good reasons
marcjagman
posted on 7/1/10 at 06:01 PM Reply With Quote
Drill holes in them?
NigeEss
posted on 7/1/10 at 06:18 PM Reply With Quote
AFAIK hydraulic handbrakes aren't as long as there s a mechanical parking method.
Hole in tran tunnel and a screwy in the prop flange passed many an mot on a friends rally car !!
posted on 7/1/10 at 07:37 PM Reply With Quote
Passing an MOT at a friendly station and passing IVA are two very different things.
Hydraulic will not pass... nor will a 'screwy in the prop flange'.
Why would you want hydraulic AND mechanical handbrake anyway?
It's Evolution Baby!
blakep82
posted on 7/1/10 at 07:42 PM Reply With Quote
mechanical for parking, and hydraulic for hand brake turns round tight corners on a rally stage i think
________________________
NigeEss
posted on 7/1/10 at 07:47 PM Reply With Quote
Good point
Triggerhappy
posted on 7/1/10 at 08:07 PM Reply With Quote
I just need to pass swedish IVA and then im prepared to scrap heavy rear calipers and handbrake wires and justhook in to rear brake line passing down the tunnel and put on some neat calipers.
Don´t expect to need very reliable HB in paddock....the are basically flat on our swedish tracks...
Milling out some material from rotor hub and drill/groove disks is an option but machining also costs money...so if there is any "ready made" non fat disk´s out there...im intressted!
