prelude1980
| posted on 7/1/10 at 07:58 PM |
Splitting Battery Cable
How do you neatly split the main battery cable to a 6 fuse box. The cable is too big to fit in the crimped terminal. I have currently soldered the
crimp terminals together in a row and solder the battery cable to the first terminal, I think it looks Pants
Open to suggestions
Speed has never killed anyone. Suddenly becoming stationary... that's what
gets you.
https://www.topcashback.co.uk/ref/dodd1980
petercd
| posted on 7/1/10 at 08:08 PM |
The thick main batt cable goes directly to the starter motor, smaller wire (30 Amp) is attached to the batt terminal which then feeds the main fuse
box.
MakeEverything
Open to suggestions
Via a main battery relay?
Kindest Regards,
Richard.
blakep82
| posted on 7/1/10 at 08:11 PM |
i bought some of these
cleeeeek
wire the cable to your battery cable where it meets the starter for perm live
i bought 2 kits. one for the permanat live stuff, the other for the switched stuff
[Edited on 7/1/10 by blakep82]
________________________
prelude1980
| posted on 7/1/10 at 08:13 PM |
cleeeeek
I like that idea looks very neat, by the sounds of it i'm trying to use to thick a cable, I'll give it a go with thinner cable.
gets you.
| posted on 7/1/10 at 08:26 PM |
Wire from the live side of the starter solenoid to either a Midi or fuse holder with a suitable fuse.
A midi fuse holder will accept up to 16mm^2 cable but 10mm^2 70amp should be OK
| posted on 7/1/10 at 08:28 PM |
Midi fuse
see http://www.the12voltshop.co.uk/Shop/fuses-and-holders/fuses-midi-and-mega/
prelude1980
| posted on 7/1/10 at 08:36 PM |
I've got one of those but i've put that directly on the battery then feeding the fuses.
Is that wrong?
gets you.
marcjagman
Why not try a splitter like you use on a sound system?
big_wasa
| posted on 7/1/10 at 08:37 PM |
Ive done bothe the above.
