carpmart
posted on 12/1/10 at 12:00 PM |
To remove thermostat or not?
Hi Chaps
Need some input into a decision I'm trying to make!
I race a Drakart (www.drakart.co.uk) which has a 919 RRT Fireblade engine in it! I pretty certain my engine temps are OK but only just marginally on
the side of OK! I run this with a CBR 600 CDi unit too so I'm getting 1,000 more RPM before the limiter!
So, based on the fact that we rag these engines to the max and that a little restriction removed from the coolant path has to be a good thing, is
there any downside to removing the thermostat? Or indeed any real upside?
I will of course spend a little more time with a cooler engine as there will be a greater volume of coolant circulating from start up, but I can
handle this by spending more time warming her up!
What do you think?
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
l0rd
posted on 12/1/10 at 12:06 PM |
all i know, some engines for car, like to run a bit hot.
Steve G
posted on 12/1/10 at 12:07 PM |
I think removing the thermostat is a bit of a bodge to try and make up for the cooling system not being up to the job. I'd rather do the job
properly and figure out where the limiting factor is - either needing the radiator upgrading, sorting the flow via ducting to the current one, or
rerouting the cooling system if its not optimum.
carpmart
posted on 12/1/10 at 12:15 PM |
OK, I can see why you are saying that!
The rad is a pretty large one for a bike engine and positioned well to receive lots of airflow and in 'normal' service just about is OK
doing its job of keeping the engine in its optimum temperature range. I'm happy this is all sized about right.
My question is just one of is there any downside that I haven't considered from removing the thermostat?
The upside I see is a little more cooling through improved flow, thus giving me a little more margin again!
Hope that makes sense?
'94 MX5 MK1, 1.8
blakep82
posted on 12/1/10 at 12:16 PM |
since the thermostat sits in the top hose connection, that'll be the restriction he's talking about! i guess the water pump trying to push
against a flap of metal in the coolant path could cause a fairly big restriction at high engine speed
if its a race engine, the main aim is to win races, try it. if it give a little extra performance, and you win then all good, if it blows up, leave it
in your next engine. i guess race engines are fairly consumable items?
i suppose the engine my run a little cooler (if it was a road car engine... i don't suppose a race engine has a chance to get cold) you will
need to give it extra time to warm up before a race i guess
[Edited on 12/1/10 by blakep82]
________________________
Steve G
posted on 12/1/10 at 12:21 PM |
If it runs too cool then you will lose performance so i think you will do potentially more harm by removing it. Its there to keep the engine in its
optimum range and i cant believe that Honda would make it so small that it'd be a restriction
designer
A mate of mine, year ago, removed the thermostat, replacing it with a disc with a hole, approximately 1/2 the size of the thermostat, in it.
Apparently this way restricts the flow enough to ensure cooling still takes place.
posted on 12/1/10 at 12:23 PM |
Thermostat also act as a restrictor for a reason in a lot of engines. A series for one will crack the head around the exhaust ports/valve seats due to
cavitation which is why they should be fitted with a restictor if the stat is removed . Try a bottle of Water Wetter, if it's good enough for F1
posted on 12/1/10 at 12:53 PM |
Yup. Some water wetter is more likely to help. If you remove the thermostat you'll take absolutely ages to warm the engine up (ie lots of time
for wear and tear to occur) and you might even make the cooling work worse....
russbost
posted on 12/1/10 at 01:15 PM |
Another vote for water wetter, definitely made a difference on my 2 Kawasaki's.
The upside with water wetter is that warm up is faster whilst cooling available is increased - there is good physics behind it I believe.
dazzx10r
posted on 12/1/10 at 09:39 PM |
never had a thermostat in my last 2 race bikes (Kawasaki ZX10r '05, Suzuki GSXR1000 '08). never had any troubles with them, also ran them
without cooling fans.
posted on 13/1/10 at 11:16 AM |
It might be an idea to put an accurate number on the the temperatures (1) Cylinder head outlet (2) Radiator outlet.
If the radiator outlet temp is high it is a sign the raddiator hasn't enough area or airflow for its job.
If the cylinder head outlet temperature is high but radiator outlet temperature is low when the engine is fully warmed up you should look towards the
thermostat or waterpump or engine or possible airlocks .
norfolkluego
posted on 13/1/10 at 12:28 PM |
I might seem that removing the T/stat would aid cooling but not necessarily, if the coolant circulates too quickly it might heat away more quickly but
it won't take as much heat away a.k.a. less cooling. Leave the stat and use Water Wetter as said
aitch
posted on 13/1/10 at 02:55 PM |
the thermostat restricts flow deliberately to maintain correct cooling
when having my hayabusa dyno'd the max power has always been acheived when all temps are on the hot side of ok, so id say your thermostat is
doing exactly what its designed to do, so dont remove it
while as your hammering it all the time it might stay within acceptable limits will probably be on the cold side without thermostat, reducung power
and worse still possibly cause damage running an engine cold on full chat, bike engines have lower tollerances than cars and must run at correct
temps
aitch![](/images//smilies/cool.gif)
carpmart
posted on 13/1/10 at 03:44 PM |
Thanks for all the comments and input!
I think I'm going to procure some water wetter!
'94 MX5 MK1, 1.8
