The Venom Project
posted on 13/1/10 at 07:35 AM |
Exhaust bracket / Mount
I will be using 2 x exhausts on my car and for long runs (With the wife) I will need the stock silencer fitting, but for thrashing around local
streets I will be fitting a regular Mirron or Art can, I have made a stainless plate to mount the 2 x different lengths of exhaust to, but what do I
use to wrap around the exhaust? I have made a stainless band, but I need some rubber for that to sit in or it will scratch my original?
Any pictures of peoples exhaust mounts would be most appreciated
Nick
A1
posted on 13/1/10 at 11:24 AM |
There was a lug welded to my silencer, so I made a wee L shaped bracket that bolts on underneath the car, so when I take it off you cant see the
holes![](/images//smilies/smile.gif)
TimC
posted on 13/1/10 at 11:36 AM |
Yes, I had a lug welded too.
Very big Image here.
fesycresy
posted on 13/1/10 at 12:48 PM |
My old car, with a stainless bar rivnutted under the chassis and a standard end can clamp.
I used a mini exhaust bobbin to take out the vibration. This was fixed to the stainless plate and a nut on top through the band.
bassett
posted on 13/1/10 at 01:39 PM |
I had a similar issue but mine was that i was fitting a short decat and a long cat so the exhaust would move back for sva and forward post sva.
Simplist thing i could thing of was to make a very strong L bracket i think its 3-4mm thick and has two holes on the vertical side and is bolted to
the chassis and floor using 4 bolts that are spaced from the tub to prevent holding it too tightly. The exhaust also has a welded bracket on to mount
vertically
James
posted on 13/1/10 at 02:46 PM |
Cheap and easy way...
ear plugs for the Mrs!
- Muhammad Ali
aitch
posted on 13/1/10 at 03:32 PM |
what width is your exhaust strap ?
i supply protective rubber with my bike cans and 25mm wide straps..
if its suitable id be happy to send you some just u2u me with the length you need and your address
aitch![](/images//smilies/cool.gif)
The Venom Project
posted on 22/1/10 at 09:01 AM |
Exhaust Mount
My friend fabricated me the triangle section of this bracket and I welded on the two mounting plates, I am pretty happy with it. but due to the length
of the silencer, I will have to fabricate a slash cut pipe for the end of the silencer as its very close to the rear wing / tyre. I like the sound of
the original can so may indeed just keep that, plus our lass can warm her hand up on it :-)
![](/galpreviews/a1081485-17-01-10_1709.jpg) ![Rescued attachment 17-01-10_1709.jpg](/gallery/a1081485-17-01-10_1709.jpg) Rescued attachment 17-01-10_1709.jpg
