dan8400
posted on 13/1/10 at 03:25 PM |
Megajolt. Broken Chip..... need codes
I have assembled my megajolt lite jr but have trodden on the last chip. It is a 16 pin "Processor Freescale MC908QB8" or U1 in the
instructions.
Does anyone know if i can get one like it from maplin? What do i need to order? The code doesnt give me anything and i dont know what the chip does.
Any advice is appreciated
Dan
andyharding
posted on 13/1/10 at 03:28 PM |
Think that the brain programmed with the Megajolt code so only going to be 1 supplier of a replacement I think...
posted on 13/1/10 at 03:29 PM |
Yes - get in touch with Brent Picasso at Autosport Labs. Hopefully he'll be able to offer a replacement (I'm sure he will).
iank
posted on 13/1/10 at 03:37 PM |
Can you straighten out the pins? 16pin DIL chips are pretty robust.
Unfortunately as said it's the pre-programmed brain of the thing so it's not available from the normal suppliers.
Anonymous
James
posted on 13/1/10 at 03:52 PM |
Presumably Bill Shurvin(g?)ton or the other suppliers could help too?
- Muhammad Ali
dan8400
posted on 13/1/10 at 03:56 PM |
I have found a chip with the exact same code on a website "farnells".
Will this be any good?
It is exactly the same pin layout and model number. Does it need programming then?
Dan
blakep82
posted on 13/1/10 at 03:58 PM |
^ presumably its some kind of ROM chip, so will need programming
________________________
iank
posted on 13/1/10 at 04:09 PM |
Dan
Yes, Farnell are a good supplier if you can find someone with a programmer.
[Edited on 13/1/10 by iank]
Anonymous
posted on 13/1/10 at 04:14 PM |
It's a microcontroller, so it needs programming. As supplied with the MJ kit the micro has been programmed with a bootloader so you can update
the firmware via the MJ serial comms port. To program the bootloader onto the chip you need a proper device programmer
dan8400
posted on 13/1/10 at 04:23 PM |
Ok,
unless anyone on here can programme me a chip i'll get in touch with autosport labs to get a replacement.
Regards
Dan
posted on 13/1/10 at 04:56 PM |
You'll probably find the price very reasonable - he's not a rip-off merchant.
blakep82
posted on 13/1/10 at 06:35 PM |
thats true. megajolt could easily have been double the price it costs, for what it does and stuff
posted on 13/1/10 at 06:42 PM |
Unless you completely snapped the legs off the chip or cracked the package in half it's probably salvageable by straightening the pins
carefully. You only tend to get one go at this however, as the copper pins work harden and snap the next time.
iank
posted on 13/1/10 at 07:42 PM |
Even if you snap the legs off at the package they're still salvagable in an emergency with a turned pin socket, a good soldering iron, a dremel
and a steady hand. (flashbacks to an important demo next day and a boss disaster at 6pm!!)
Wouldn't recommend it in the car as vibration would kill it in weeks, but enough to get you going while you wait for a replacement to be sorted.
Anonymous
posted on 13/1/10 at 08:07 PM |
Did this as a temporary repair on a laptop a few days ago where someone had spilt a drink into the keyboard and it had leaked down onto the PCB and
completely rotted away one pin of a voltage regulator!
