Author: Subject: Wiring Advice for RH Loom & Bright 6 Warning Light Module
Jaybeee
posted on 15/1/10 at 11:18 PM Reply With Quote
Advice needed I have a RH Wiring loom and Bright 6 Warning Light Module. I have wired the bright 6 as directed in the documents that came with it but when I connect up to Ignition light it all works, as it should but when I turn off the ignition and remove the key the engine continues to run!
Someone suggested that I checked the voltage on the alternator. On my alternator there is 1 wiring block with 3 wires connected to it the 2 bigger wires connect to the battery and the smaller 3rd wire I have connected to the bright 6 unit, the only other wire is a single wire that connects to the auto choke unit.
Can anyone see where I've gone wrong?
Many thanks for any advice.
Jason
austin man
posted on 15/1/10 at 11:46 PM Reply With Quote
it sound like you have a permanent feed to the bright light module. are you sure the alternator is wired corrrectly ?
[Edited on 15/1/10 by austin man]
austin man
posted on 15/1/10 at 11:51 PM Reply With Quote
Try this thread some usefull diagrams on here
http://www.locostbuilders.co.uk/viewthread.php?tid=126153
RichardK
posted on 16/1/10 at 10:22 AM Reply With Quote
I had a similar issue but mine just ran on for a little while (2 or 3 secs), fitted diodes to the alt/chrage light and fan + feed and my problems gone.
P.S Also had to put a couple on the indicators too.
Rich
[Edited on 16/1/10 by RichardK]
Gallery updated 11/01/2011
Jaybeee
posted on 17/1/10 at 11:25 PM Reply With Quote
Rich
Thanks for the reply can you tell me what sort of diodes I need to buy and where do you suggest I get them from?
Jason
Krismc
posted on 25/3/11 at 05:17 PM Reply With Quote
Wish id seen this post before i damaged my first alternator and then my second one.
I have a bright 6 and same issues, burnt out the first alternator and never relised i had a problem with wiring and then the second one went just yesterday never knew it was bright 6 causing the issue.
Whats the correct diode i require and the best place too put it? and do i just need one on my alt light wire and thats it??
[Edited on 25/3/11 by Krismc]
