FFTS
| posted on 20/1/10 at 11:59 PM |
Left beam high- Right beam low then reversed!!!
Just putting a new dash and switches on Beccy (Yes she has a girls name ) This problem was present when I bought her but want to sort it out now its
being rewired.
The problem!!
Switch lights on low beam and the left is on full/right on low. Click the high beam switch and they reverse, right full left low. I'm guessing
it could maybe be a relay or could it have been wired with a couple of wires mixed up and going to opposite switches? The high beam switch at present
is a simple 3 contact toggle. When its sorted its going onto a Savage switch.
Any suggestions?
Chris.
woolly
| posted on 21/1/10 at 12:10 AM |
sounds like the left hand bulb has crossed wires at the bulb connector.
woolly
brianthemagical
| posted on 21/1/10 at 12:11 AM |
Assuming it's a H4 or something similar then the wires being the wrong way round on the buld plug would be my first port of call.
miikae
| posted on 21/1/10 at 12:14 AM |
As above wires transposed.
Mike
If it can be done it i will be done .
FFTS
| posted on 21/1/10 at 12:22 AM |
Lights are on one switch and the high beam on a totally separate toggle switch so its not just the plug wiring I guess.
Ill check at the bulb conector end tomorrow.
[Edited on 21/1/10 by FFTS]
Chris.
russbost
| posted on 21/1/10 at 08:37 AM |
doesn't make any difference how it's wired, the connections are the wrong way round at the lamp itself
stevebubs
| posted on 21/1/10 at 12:37 PM |
Fourthed...
RAYLEE29
| posted on 21/1/10 at 01:59 PM |
Agreed swap two non earth wires on l/h bulb wiring
you may be able to remove them from the plug if you use a small screwdriver
Ray
also just check both bulbs are the right way up!
shouldnt be able to fit the wrong way but if the reflector is in wrong then you could
