norfolkluego
| posted on 23/1/10 at 08:11 PM |
Megajolt question
Bear with me this could be a stupid question (Zetec blacktop/Edis/ Megajolt BTW).
Following the MJ instructions my crank sensor would point a 9 o'clock on the trigger wheel (15 degrees BTDC cylinder 1). It would be a lot
easier for me to mount it at 3 o'clock.
3 o'clock would be 15 degrees BTDC cylinder 4 - yes?
3 o'clock would spark cylinders 1 and 4 exactly as 9 o'clock would - yes?
The crank sensor mounted at 3 o'clock would function exactly the same as at 9 o'clock and MJ would function OK - yes?
blakep82
| posted on 23/1/10 at 08:15 PM |
yes.
it doesn't matter where the actual sensor or missing tooth is mounted, but if you set your engine to TDC, put the sensor wherever you want to
put it, then set the trigger wheel so it points at the 9th tooth of the trigger (anti clockwise from the missing tooth).
[Edited on 23/1/10 by blakep82]
________________________
RichardK
| posted on 23/1/10 at 08:39 PM |
Yes, as above^^^
How I did mine..
Rich
Gallery updated 11/01/2011
ashg
| posted on 23/1/10 at 11:38 PM |
i did it exactly the same as rich.
set the engine at tdc, put the sensor at 3 o'clock then count 9 teeth anticlockwise from the missing one and aim that 9th tooth at the
sensor.
as usual picture says 1000 words
[Edited on 23/1/10 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Danozeman
| posted on 24/1/10 at 10:11 AM |
If you using a zetec how come youv got a trigger wheel and not using the flywheel??
Dan
norfolkluego
| posted on 24/1/10 at 05:33 PM |
CVH flywheel, around 4kg lighter but no timing marks
