dan8400
posted on 25/1/10 at 07:02 PM |
Quick TPS question this time
I have a ford TPS on my zx6r carbs. Which wire goes to where. (Using megajolt)
I assume one's earth, one's live and the other goes to the megajolt??
Dan
big_wasa
posted on 25/1/10 at 07:12 PM |
dan8400
posted on 25/1/10 at 07:14 PM |
So:
'A' is earth
'B' is to megajolt and
'C' is +12volts?
dhutch
posted on 25/1/10 at 08:19 PM |
Inside the TPS its just a potentiometer.
Like this. http://sub.allaboutcircuits.com/images/05112.png
So you ground one side and supply the other with a reference voltage (vref). Then the central contact outputs a voltage between 0v and vref dependent
on position. With the megajolt this is set up such that voltage increases with throttle opening.
See here.
http://www.autosportlabs.net/MJLJ_V4_vehicle_installation_guide#TPS_Sensor_operation
Hence the central one will always go to the tps input, but the 1st and 3rd pin will vary depending on the layout of the tps and installation.
Hope this makes sence.
Daniel
dan8400
posted on 26/1/10 at 06:48 AM |
Yes that makes sense. Is the feed to the tps +12 volts??
cd.thomson
posted on 26/1/10 at 06:56 AM |
the "feed" is the vref signal from megajolt so 1 wire goes to ground and two wires go from the tps to the MJ unit.
I believe its labelled as "VREF" and "TPS" on the megajolt wiring diagrams.
I did mine last weekend too! because there are only three wires I just tried the various wiring possibilities until i got a sensible tps reading on
the megajolt tuner..
Craig
dan8400
posted on 26/1/10 at 07:15 AM |
Wow cool. Sounds easier than i thought
