Bumble
| posted on 11/2/10 at 10:46 PM |
Help DigiDash Sensors 4 Zetec
Help please.....I've just bought a Digidash 2 from E-Bay.....arrived today and it's immaculate, all still wrapped. All present &
correct apart from water & oil temp sensors. There are two on ETB website, 1/8NPTF and 5/8UNF. Which ones do I need for Silvertop Zetec. Also,
any advice on fitting the DD2 and all sensors and their locations would be very welocome. For info I'm also using a Raceline water rail, polo
rad with MS1 V.3.
Matt
McLannahan
| posted on 11/2/10 at 10:57 PM |
Matt - Do you have the laminated wiring diagram that came with it originally?
Really nice and easy to follow.
Here if you don't?
http://www.etbinstruments.com/DigidashDownloads_Pdf/2007/DD2_Lite%20Manual/quickwire_lite_2_GPS.pdf
Bumble
| posted on 11/2/10 at 11:12 PM |
Here if you don't?
Yes I do but thanks anyway. After advice on what temp sensors I need and also how have people fitted the speed sensor?
Matt
neilp1
| posted on 17/2/10 at 02:48 PM |
I fitted the speed sensor to the drive shaft. I made a bracket which fitted to the diff with an M12 bolt (there was a nice hole on the diff casing for
the bracket), stuck the magnets to the drive shaft.
I had thought of putting it on the propshaft, but after being underneath the car decided the best place was the diff.
As for the sensors, I used the ones supplied.
