andrew-theasby
| posted on 11/2/10 at 11:22 PM |
Astra GTE digidash
Has anybody used one for starters, im looking for pics or ideas for possibly making it look a bit different. Ive found someone who used to sell films
to change the colour of the displays. I was also wondering about splitting the clocks though i think the pcb would make this difficult. Ive had mine
just about wired up ages ago, but i cant decide whether i prefer it to the vapor dash as its rather big, but does have all the gauges i need.
55ant
| posted on 11/2/10 at 11:24 PM |
i think some of the mk1 mr2 guys have used them, they fit the retro sytle aswell, head over to mr2oc.co.uk for a looksy i reckon,
| posted on 11/2/10 at 11:27 PM |
have you ever driven an astra with one fitted?
i had one so I woldn't bother - more of a gimick and not as useful as dials.
a qick look at current dashboards and you will see that almost all cars use dials - there is a reason for that - mainly that dials are easier and
quicker to read.
andrew-theasby
| posted on 11/2/10 at 11:42 PM |
Thanks, i only managed to find one reference to it on the mr2 forum but worth a look.
quicker to read.
Must admit i had wondered that, and wheter it would flicker between speeds? Either way vapor or astra theyll both be digital, as i like gadgets
just wanting to not make it look like its straight out of a 20 year old car. Ive already cut the fascia off to mount it flush behind the dash
panel, just looking for other posibilities? thanks
Mr G
| posted on 12/2/10 at 12:29 AM |
The increments on the fuel guage are very large so you have a terrible time working out how much you have in the tank which is the last thing you want
in a kit car.
There was a website that detailed changing over the illumination from orange to blue via different coloured leds which involved a solder job.
| posted on 12/2/10 at 08:00 AM |
no, no flickering.
it is all about human user interfaces.... i won;t bore you with details....
we humans have been seeing pictures far longer than letters or numbers so our eyes and brain pick up information quicker from pictures.
a needle on rev counter, not only will respond qucker than the curverd lcd display you have on that dash plus the brain processes the info quicker.
do the experiment yourself.
wear a digital watch and an analogue (with hands).
when asked the time, you will look at the hands and know immediately it is quarter to eight whereas it will take you several seconds to work out what
19:43 means, or 7:43.
Also with the speedo, you know the position of 70 mph on the dial but when you have that digial speedo, sometimes it take a bit of time to spot the
differene between 68 and 88 or 98 mph .....
digidash and vapour etc. show speed as digits since it is easier/cheaper to make them like that I suppose.
Ben_Copeland
| posted on 12/2/10 at 08:13 AM |
I used to play around with them alot when i was younger.... One thing i noticed about them is, if you have a fast car Astra GTE or faster it cant
keep up with the accelaration.
My friend had one in a Turbo'd AStra it was useless as it accelarated faster than the dash could keep up..... so a kitcar its going to have no
hope.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
whitestu
| posted on 12/2/10 at 08:37 AM |
I agree with you in general, but hopefully most of us could work out what 19:43 means quicker than several seconds!
Richard Quinn
| posted on 12/2/10 at 08:39 AM |
I beg to differ on a few of these
I am not aware of any reason why a curved LCD tacho display can't respond as fast as an analogue tacho. I have an LCD tacho and it keeps up with
my bike engine without much of an issue.
As for the watch experiment: Well I wore digital watches for years and went back to analogue last year. It has taken a bit of getting used to! To me,
7:43 or 19:43 has been nearly quarter to eight for years. It is what you are used to!
Knowing roughly where 70mph is on your speedo is good but I drive a number of different cars and 70 on the speedo tends to be in a few different
places depending on which car it is. Unless you are driving a Rolls Royce Phantom or something, you normally have more to help you with the instant
judgement between a speed in the 60's, 80's or 90's. Also, a significant number of French and Japanese manufacturers now seem to be
going back to digital speedos.
I think that this is mostly down to personal taste and what you are used to rather than anything else.
55ant
| posted on 12/2/10 at 08:51 AM |
what about a new civic dash, the one in a freinds type r keeps up very well in terms of speed.
away from cars, now cycling and building TT bikes
andrew-theasby
| posted on 12/2/10 at 11:16 AM |
Thanks for the coomments, but i wont be using dials either way, just wanted to see if anyone had done anything interesting with the mounting of the
astra dash to make it unique more than the vapor dash. The fuel gauge wont be an issue either as the vapor doesnt even have one, and as long as i
know when its fairly low, thats all i need to know. Ill also have some shift lights for the revs anyway, but to be honest you pretty much know when
to change gear by ear anyway, it is just a toy for me, which im sure is why most people use digital dashes. Regarding other digital dashes, i already
have the astra one and all the senders as its the gte engine im using, only advantage of the vapor or similar is its smaller and very simple to wire
up.
Any pics then? astra or vapor? Thanks
[Edited on 12/2/10 by andrew-theasby]
| posted on 12/2/10 at 12:21 PM |
I had an Astra 16vGTE with the hideous digital dash. Whilst all the teenagers were fitting these poxy things to their Novas, I was serioulsy
contemplating fitting the SRi clocks to mine.
Bargraph type displays aren't so bad, but they don't have anything like the resolution of a traditional meter movement. Proper digital
displays are only useful for values that rarely change, or only change slowly i.e. time and temperature, but definitely not RPM or speed.
Charlie_Zetec
| posted on 12/2/10 at 01:26 PM |
I retrofitted the digidash to my 1600 Mk2 Astra with a set of Webbers on it. I thought it was good, especially as I had the 5-door GTE sideskirts and
bumpers. My first real modded car in my youth, lol.
I did find that the speedo wasn't directly accurate when accelerating (cue jokes about the capability of acceleration on a 1.6l....), and as
such I'm not sure it would be best suited to a 7. But the bargraph style rev counter had no problems whatsoever and seemed wholly accurate.
I quite liked the dash as it was a feature of a proper flagship hothatch of the time, and it definatley suited the Astra. But looking back now, it
does seem a little dated and is best left with the rare breed that is the GTE (or at least clean versions thereof).
However, one of the things also to be noted was that it read your speed inreverse as well..... made for some fun and games!
boggle
| posted on 13/2/10 at 06:43 PM |
we had a digi dash in our meastro vanden plas......and the car talked to you.....
u2u me for details
