blakep82
posted on 12/2/10 at 02:01 PM |
alternator adjusters
would i need something like the turnbuckle in this one
or would the slidey arrangement where you pull it back and tighten be fine?
the belt only drives the alternator on my car, so no atomatic tensioners etc, just 2 pulleys and a belt
could anyone make me alloy tunbuckle thingy for me? left and right hand threads, for rod ends, not sure of the length yet. i can do the other style
easy enough. just wondering whats best first
[Edited on 12/2/10 by blakep82]
________________________
posted on 12/2/10 at 02:05 PM |
Slotted bracket off a Pinto or CVH should be fine but if you want a turn buckle look at the McGill Motorsports shop on EBay.
cd.thomson
posted on 12/2/10 at 02:08 PM |
lol you should see how basic mine is, I've just fitted a right angled bracket to the bottom right inlet manifold stud!
Craig
andrew-theasby
posted on 12/2/10 at 02:09 PM |
i just used 2 rose joints from mcgill
irvined
posted on 12/2/10 at 02:10 PM |
Slidey bracket will be fine, but turnbuckles do look nice
I drove all the way down through morocco without any supporting bracket due to a snapped bolt, didn't have any problem with the alternator
coming loose, so it doesn't need to be anything all that substantial.
http://irvined.blogspot.com
blakep82
posted on 12/2/10 at 02:13 PM |
slidey bracket it is then
mcgills turnbuckles are all too long. i looked at 2 female rod ends with 8mm threaded bar, but difficult to adjust properly.
slidey bar can just be made easy enough. wasn't sure how easy it would be to get the right tension in the belt though
MikeR
posted on 12/2/10 at 02:15 PM |
[sob] [sob] my poor alternator!
andrew-theasby
posted on 12/2/10 at 02:17 PM |
Mines 1 male, 1 female, very short but only just enough adjustment. A solid bracket will be fine though
blakep82
posted on 12/2/10 at 02:27 PM |
oh yeah, i see that now
you still have to pull the alternator by hand before it all fits together though, in which case, slidey bar might be easier
posted on 12/2/10 at 02:41 PM |
slotted metal strip will work fine.
if you wantto get fancy, but not to trunbuckle prices, then a couple of bolts and one of these:
(studding connector) lock nut and jobby done.
[Edited on 12/2/10 by 02GF74]
Slater
posted on 12/2/10 at 03:15 PM |
you can get various sized turnbuckles from most chandlery stores
blakep82
posted on 12/2/10 at 03:42 PM |
just drew this up
set my alternator to where it needs to be (i think) to clear carbs and steering, and the distance between holes is 16cm, so needs to be quite long
really. the curve out the bottom is to clear the alternator
Daddylonglegs
posted on 12/2/10 at 03:52 PM |
God we're an inventive lot
cd.thomson
posted on 12/2/10 at 03:56 PM |
thats the same as mine but theres a right angle just before the left hand hole so that it can be mounted to the inlet manifold stud
Craig
blakep82
posted on 12/2/10 at 04:04 PM |
i'm going to use the bolts originally used, you can see in this photo, there's a bolt sticking out below the black rubber hose, it's
going on there
jacko
posted on 12/2/10 at 07:13 PM |
Ship's chandler's where you want to be they have all sorts of fancy ajusters
Bigheppy
posted on 12/2/10 at 07:21 PM |
Have a look at a citroen saxo adjuster, it has a bolt to adjust it then locked in place with a nut.
