Author: Subject: type 9 speedo rotations
cd.thomson
posted on 14/2/10 at 06:23 PM Reply With Quote
good evening,
i tried to measure the turns of my speedo cable today ready to replace it with an electronic sender.
I jacked the back of the car up and put it into neutral. Turning the wheels one rotation resulted in prop turning 3.62 times (which is my diff ratio) and the cable turning exactly once.
this seems highly unlikely to me, the speedo cable rotates once for every one wheel rotation and I just happen to have the right diff to make this happen?
am i missing something obvious?
Craig
blakep82
posted on 14/2/10 at 07:45 PM Reply With Quote
sounds a happy coincidence to me. isn't the 3.62 diff like the middle one out the sierra range?
maybe its like that to make calibrating sierra speedos easier?
________________________
mcerd1
posted on 14/2/10 at 09:49 PM Reply With Quote
I'm want to know the answer to this one (you a fair bit ahead of me)
all I know is that there are at least 3 different drive gears with 24 , 23 or 22 teeth (I assume thats how for calibrate for the range of diffs)
bbwales
posted on 14/2/10 at 10:53 PM Reply With Quote
Hi
Sorry to steal the thread but where do you get the electric sender from.
Bob
blakep82
posted on 15/2/10 at 01:15 AM Reply With Quote
Originally posted by bbwales
Hi
Bob
i got mine from burton power, but you also need the adapter too
cd.thomson
posted on 15/2/10 at 08:54 AM Reply With Quote
okay... happy coincidence it is then, just wait a couple of month for the "my F*@$ng speedo wont work" post
here are the bits you need:
http://shop.ebay.co.uk/i.html?_nkw=type+9+electronic&_sacat=0&_trksid=p3286.m270.l1313&_odkw=type+9+sender&_osacat=0
Craig
bbwales
posted on 15/2/10 at 09:14 AM Reply With Quote
Thanks guys for the information, can I ask another question though? will this device drive my KOSO speedo?
Bob
posted on 15/2/10 at 09:34 AM Reply With Quote
speedo gearing from fnal drive on a lot of cars is about 4:1.
cd.thomson
posted on 15/2/10 at 09:38 AM Reply With Quote
yes i believe so.
My smiths speedo requires two pieces of information, pulses from the sender per rotation of the wheel and the distance covered by the wheel in one rotation.
Check your manual as this is probably the same with the KOSO.
Craig
blakep82
posted on 15/2/10 at 08:57 PM Reply With Quote
Bob
got no expericnce in the koso speedo, but basically, the sensor puts out a signal, and you set up the speedo to give the correct speed reading for a the output.
