Danozeman
| posted on 16/2/10 at 01:57 PM |
acewell dash tank sender ohms.
Does anyone what resistance the tank sender needs to be for an acewell dash?
Dan
prawnabie
| posted on 16/2/10 at 02:10 PM |
You can choose between 3 on the settings. Can't remember which ones there are but if you look on the acewell page it tells you.
Shaun
Danozeman
| posted on 16/2/10 at 02:14 PM |
Im sure mines got no choice. Its a basic one. 3150 i think.
Dan
tomprescott
| posted on 16/2/10 at 02:26 PM |
I think it can be 4 or 8 from memory, check on their site.
prawnabie
| posted on 16/2/10 at 03:14 PM |
http://www.acewell-meter.co.uk/en_uk/specifications/index.htm
100/250/500 ohm settings (or off)
Thinking about it
| posted on 16/2/10 at 03:29 PM |
I asked the same question to russbost on here from who I bought mine.
Hi Ian
It will work with (almost) any fuel sender. Acewell do 1 themselves but it's quite pricey at £39.95. Can order one if you want or if I can give
anymore info just ask.
Regards Russ
Hi Russ
While your on I bought an Acewell speedo from you some time back. Any recommendations on a suitable fuel sender to suit?
Ian
Reply - Forward
[Edited on 16/2/10 by Thinking about it]
DavidW
| posted on 16/2/10 at 03:53 PM |
I have that model and you can change it.
I have the instructions somewhere id you get stuck.
Danozeman
| posted on 16/2/10 at 04:48 PM |
Instructions would be good if you can find them David. Iv lost mine and cant find them online anymore.
Dan
omega 24 v6
| posted on 16/2/10 at 04:52 PM |
I'd bee interested in the instructions on how to do it as well if anyone can oblige
Danozeman
| posted on 16/2/10 at 04:53 PM |
Call me dim iv just found them on the acewell site. It says fuel resistance is 100 ohm. Nothing about altering it.
Failing that does anyone know what an ldv pilot fuel sender resistance is.
Dan
omega 24 v6
| posted on 16/2/10 at 05:07 PM |
I'm with you Danozeman. My unit is on the car and working ( gsxr pump and sender cant remeber the resistance though.
It does work but falls from full to empty too quickly i.e. not linear with level. I di run out of once so know when it start to flash i have around
50miles grace before I'm in the poop
Danozeman
| posted on 16/2/10 at 09:00 PM |
Iv never ran mine with the acewell gauge. I have a smiths one atm but want to use the acewell as the flashing is annoying.
Dan
DavidW
| posted on 16/2/10 at 09:26 PM |
My Acewell is the one russbost sells. I think it's a 3150 or 3250?
Anyway I've dug out the instructions and although I've set mine up I don't how I deciphered the steps.
It looks like you hold down the mode and reset buttons for 2 seconds to go into setup mode.
Use the mode button to cycle through the different functions.
After your gone through the few of the functions you get to the fuel sender one and I'll quote from the "instructions"
"It dispalys '100r' and fuel tank symbol', follow item 2 (press the reset button) to select 100, 250, 510 Ohm or off and
return to the main screen. The fuel meter bar will disspear if you select off mode"
Hope this helps. I gues you could solder a resisor with the sender if you couldn't find a range that works?
Dan, you're welcome to pop over to Debenham if you want a go with the instructions.
Regards
Danozeman
| posted on 17/2/10 at 05:47 PM |
Il try that later. Is yours the 3250? That does more stuff than the 3150.
I may well pop over and have a gander if i cant do it thanks mate.
Dan
DavidW
| posted on 17/2/10 at 09:50 PM |
I looked today and mine is a 3250 so maybe different?
