Miks15
posted on 17/2/10 at 05:47 PM |
Fuel sender - acewell
Can someone help me source a universal fuel tank sender to work with an acewell dash.
My tank is 200mm high.
Mikkel
russbost
posted on 17/2/10 at 06:01 PM |
Acewell do one of their own, tho' it's not cheap at £39.95, I'm away on hols at the mo, can check dimensions on my return next
week.
Russ
whitestu
posted on 17/2/10 at 06:03 PM |
I used a Sierra one with mine.
Miks15
posted on 17/2/10 at 06:37 PM |
Having a quick look online the acewell one only goes to 128mm deep? Can this be right?
Is it able to be bent a bit to make it the right shape?
Although ideally looking to have a cheaper (£20ish) universal one that will work?
prelude1980
posted on 17/2/10 at 07:02 PM |
i bought a marine fuel sender they came in all different sizes, i'll try to find a link to show you
http://www.marinemegastore.com/product.asp?pf_id=AQU_Q96272&jump=4&cat_id=ENGINS004&cid=IXPD2L0CXCCA06D9H8OT8FBUZFDFZ4Y2
but i found somewhere a bit cheaper than this but can't for the life of me remember where
[Edited on 17/2/10 by prelude1980]
Speed has never killed anyone. Suddenly becoming stationary... that's what
gets you.
https://www.topcashback.co.uk/ref/dodd1980
midge
posted on 17/2/10 at 07:07 PM |
I bought mine from BanditMania, £30ish and had to make a new arm to suit the fuel tank. The sender unit has to be a 100 ohms (from memory) to work
properly. I couldn't find a universal one with the correct output.
HTH
Miks15
posted on 17/2/10 at 11:15 PM |
OK thanks will look into it
