adrianreeve
posted on 18/2/10 at 02:35 PM |
How much current does a fuel pump draw?
Anyone know roughly how much current a fuel injection pump will draw? It's a standard vauxhall astra type one. Just trying to work out if the
wiring I have in place is man enough for the job!
Adrian
stuart_g
posted on 18/2/10 at 02:38 PM |
Not sure how much that actual pump will draw but fuel pump circuit is normally fused at 10amps.
posted on 18/2/10 at 04:34 PM |
The one on my bike engine draws 4A running flat out..
posted on 18/2/10 at 07:43 PM |
I think that my bike engine pump is running via a 5A fuse...
flak monkey
posted on 18/2/10 at 08:43 PM |
My walbro GSL392 says the supply should be fused with a 20A fuse.....
That said, I always ran my old pumps both off a 10A fuse with no problem.
Sera
http://www.motosera.com
posted on 18/2/10 at 09:27 PM |
Standard Kawasaki engined Kawasaki pumped fuel pump runs a 10A Fuse. Same as fitted on the bike.
