Author: Subject: Led indicators
roadrunner
posted on 20/2/10 at 07:45 PM Reply With Quote
Led indicators
I am in the process of changing my back lights for LED units.
I got the first indicator wired up and i thought i would give it a try to compare it to the standard unit. The indicator flashed twice as fast as it should.
Is this down to the fact that LEDs use less power than bulbs, if so how can resolve this problem.
Thanks in advance.
Brad.
mackei23b
posted on 20/2/10 at 07:59 PM Reply With Quote
yes, you need an led flasher unit.
cheers
Ian
bodger
posted on 20/2/10 at 08:09 PM Reply With Quote
Or a resistor wired in parallel - 10 Ohm, 50w mounted on some ally to act as a heatsink.
Canada EH!
posted on 20/2/10 at 11:37 PM Reply With Quote
almost off topic, but as you seem to be getting a little snow over there, we have noticed on lorries with led's there is not enough heat generated to clear the snow off the lights.
snapper
posted on 21/2/10 at 07:34 AM Reply With Quote
I bought a flasher relay for LED's from ebay, £10, its a timed relay so flashes at the right speed whatever bulbs you have.
I eat to survive
I drink to forget
