Author: Subject: bypassing immobiliser?
daniel mason
posted on 25/2/10 at 09:38 PM Reply With Quote
have stripped down some of my donor now but there appears to be a fault on the alarm. as soon as voltage is applied to the battery the alarm sounds and will not turn off. i have stipped most interior pannels/ carpets and located the alarm box which was under the seat. i have disconnected alarm by un plugging the main connector block (loom) at the alarm box. i can now connect battery and all electrics work fine,windows,mirors,electric roof,lights,hazzards. but engine start button does not start the car.its still immobilised and was wondering how to bypass this to try to start the car?
Ben_Copeland
posted on 25/2/10 at 09:41 PM Reply With Quote
You'll need to trace the wires back from the alarm box.. Good alarm/immobilisers have 2 "cuts" in the ignition circuit.
Check for wires joining either side of cut wires, if u see what i mean.
If its a factory fit one, it may be trickier to find them
[Edited on 25/2/10 by Ben_Copeland]
Ben
Locost Map on Google Maps
Enter Your Details Here
daniel mason
posted on 25/2/10 at 09:58 PM Reply With Quote
what do these cuts look like?
Ben_Copeland
posted on 25/2/10 at 10:05 PM Reply With Quote
if its an aftermarket alarm it'll be simply an ignition wire cut in two and two wires from the alarm going to either side of the cars wire.
if its a factory one you'll have to trace each wire and try work out what they do...
Ben
MkIndy7
posted on 25/2/10 at 10:07 PM Reply With Quote
Have you tried leaving the Car/battery/ Alarm "on charge" with another large battery or a powerful charger while its blarering away?.
If I ever let my Cat1 alarm go completely dead it needs a few minutes to charge the battery in the alarm sounder before the main alarm unit works properly.
daniel mason
posted on 25/2/10 at 10:11 PM Reply With Quote
not tried that mate. just need to bypass the complete alarm system to try and start the car
l0rd
posted on 26/2/10 at 08:02 AM Reply With Quote
did the car come in with a logbook?
Do you have a V5?
Might worth trying to find the previous owner to ask for a code?
McLannahan
posted on 26/2/10 at 08:20 AM Reply With Quote
I wouldn't be surprised if the immobiliser was encoded into the ECU on an S2000
I don't think it'll be an easy job unless it's had an aftermarket one fitted.
Are you using the original key and is it a chipped one?
Edit - was just reading the M3 thread and put M3 and had that in my head!
[Edited on 26/2/10 by McLannahan]
stuart_g
posted on 26/2/10 at 09:07 AM Reply With Quote
I doubt it will be as easy as bypassing the immobilser. I would think the key will be coded to a receiver somewhere in the car which is probably connected back to the ecu. I doubt very much you will be able to just put a couple of wires in and bypass a factory fit alarm/immob.
It sounds like the battery in the alarm sounder is flat and needs to charge up.
Have you spoken to a Honda garage yet and asked them about it? they will be able to tell you a possible reason for the alarm sounding everytime you connect the battery. Alternatively have you tried a Honda S2000 forum? there must be one.
[Edited on 26/2/10 by stuart_g]
