blueskate
| posted on 2/3/10 at 06:22 PM |
Indicators flashing too quickly
Hi all,
I've been tinkering with the car over winter, although i haven't touched the indicators. Now they flash too quickly? (both sides) although
the hazard lights work fine? I'm using a durite flasher unit and standard bulbs all round.
Any ideas?
Thanks!
Semper Paratus!
INDY BIRD
| posted on 2/3/10 at 06:27 PM |
Hi have you changed any lights to led etc,
normally just upping the watss on the rear/ front indicators solves this,
ie when you put hazards on its pulls more power for the relay to work,
i did this and was fine look at the watts in your current bulbs,
cheers#
sean
| posted on 2/3/10 at 06:28 PM |
Yup, usually it means there's insufficient resistance on the circuit to allow the flasher relay to work properly....
blueskate
| posted on 2/3/10 at 07:39 PM |
Thats what i read. Wierd thing is i Haven't changed any of the bulbs! I have however been tidying up the wiring (i didn't originally wire
the car). So maybe the circuit was routing through something else? Any recommendations on where to get an electronic flasher unit?
Thanks!
Semper Paratus!
vyperstrype
| posted on 2/3/10 at 08:23 PM |
flashers
I had the same problem when i built mine. The hazards worked fine, but the indicators were very fast. I originally used some bike indicators i had
been given, but i changed them for some from car builder soloutions ones which were sva compliant. These made them flash very rapidly. I went to my
Lucas agent and put some higher wattage bulbs in the fronts and cured the problem. The Bulbs are 25Watt 12Volt Bulbs, about the size of 5Watt
sidelight bulbs. You could probably get these type bulbs from a motorbike dealers.
Cheers Eric.
blueskate
| posted on 3/3/10 at 10:16 AM |
cheers eric i'll give it a go!
Semper Paratus!
blueskate
| posted on 5/3/10 at 03:15 PM |
Ok update time.. I already have 23 watt bulbs in the front indicators I'm thinking there must be wiring fault between the hazard switch and
indicator switch. Does anyone know the correct way to wire up a savage hazard switch?
Thanks!
Semper Paratus!
