| posted on 6/3/10 at 08:41 PM |
Wiper motor - rack in or rack out when stopped?
Is the rack pulled in or pushed out when a Lucas 2-speed wiper motor stops?
I'm working out which way my wiper boxes should fit...
TigerB6 Paul
| posted on 6/3/10 at 08:58 PM |
Depends on where the cam is on the wiper motor gear really - you can pull it out and move it 180degrees.
| posted on 6/3/10 at 11:09 PM |
Best bet would be to connect up the electrics and try it?
dave r
| posted on 7/3/10 at 08:15 AM |
half stealing this thread, but sort of similar, can i run 2 different sweep wheel boxes at the same time (assuming they miss hitting each other )
| posted on 7/3/10 at 08:38 AM |
That bit is still in progress!
| posted on 7/3/10 at 08:40 AM |
Can't see any reason why not
| posted on 7/3/10 at 12:43 PM |
Yes though obviously you'll only be able to change the sweep on the rocker boxes and no have different cams on the motor....
| posted on 7/3/10 at 03:29 PM |
Sorted
I now know which way mine stops (rack pushed out) and I can see how to modify it if I want it the other way.
Life's a lot easier when you can run it under power...
