austin man
| posted on 8/3/10 at 06:12 PM |
Peugot Radio code
Just managed to lock the radio out on a peugot 206 How do I reset it to allow me to enter the correct code, do I need to remove the power to it for a
while ?
suggestions please oh and yes I do have the correct code just managed to forget it
speedyxjs
| posted on 8/3/10 at 06:23 PM |
Our kangoo has to be left for a while before it will unlock. Unplugging it didnt seem to help.
austin man
| posted on 8/3/10 at 06:29 PM |
been left for 2 days still says locked
Davg
| posted on 8/3/10 at 06:54 PM |
think you should be leaving the unit powered for approx 90min to allow it to reset then should allow input of the code. Assuming you haven't
locked it totally by inputing wrong code too many times.
hth. cheers D
mike.williams1
| posted on 8/3/10 at 08:39 PM |
press and hold the band button in for a few seconds.If this does not clear then leave the ignition on for up to two hours to clear it
austin man
| posted on 8/3/10 at 09:33 PM |
the wrong code was entered 3 times will this make a difference to anything ?? then it came up saying locked
Michael
| posted on 8/3/10 at 09:38 PM |
For the first incorrect code the clearance time is 30 minutes.
For the second its doubled - 60 minutes.
For the third its doubled again - 120 minutes.
Thats the norm anyway and has to be powered throught. If the power is lost to the unit during this time then the timer starts again from the
beginning.
[Edited on 8/3/10 by Michael]
