eznfrank
| posted on 10/3/10 at 01:45 PM |
Leccy reverse and bike battery
I have an MK electric reverse and also a standard bike battery. I know the bike battery probably won't be up to the job for regular use long
term but am I only really concerned with the IVA.
So....if I charge the battery up full is the reverse likely to kill it on a one off usage for the IVA??
Flamez
| posted on 10/3/10 at 01:49 PM |
but you will have the engine running so it should be ok.
my build mac1motorsports
adam1985
| posted on 10/3/10 at 01:54 PM |
or could you just put a bigger battery on for iva
tegwin
| posted on 10/3/10 at 02:06 PM |
IVA inspectors are cunning... if they spot you have a small battery they may well test the reverse system repeatedly until the battery is flat, just
to prove a point to you... and thus fail you because the test can not be continued....
Dont give them any satisfcation....
www.verticalhorizonsmedia.tv
Lightning
| posted on 10/3/10 at 02:41 PM |
I am putting the TVR battery in as my bike battery will barely drive it backwards on the flat This is my last job to do .......hopefully
James
| posted on 10/3/10 at 03:29 PM |
Why on earth would they do that? Most people seem to say their inspector was nothing but helpful and fair. Do they want to fail us? I don't
think so- it's just more work for them in re-tests!
Either way, I'd think you could drive a BEC quite a long way on the battery. I've driven my Golf on the battery/starter the rest of the
way to the petrol station when I've run out of petrol before!!!
Quite often in the old day!!!
James
- Muhammad Ali
jimgiblett
| posted on 10/3/10 at 03:45 PM |
Using the battery when the engine is running will take so much current that it will probably stall it. The RGBers with leccy reverse quite often
struggle to reverse over a 2x2 piece of wood that they need to for scrutineering.
Both the SVA testers I have met have been very fair and want the car to pass.
They aren't vindictive but may look more harshly if they think you are taking the p*ss or that the car is presented in a way that shows little
care in the way it was contructed.
Just my 2p
- Jim
