FrankP
| posted on 16/3/10 at 05:14 PM |
Front wing indicators wiring routing
I am still looking at solutions re the side indcators and have seen them on the front and rear wings
I was wondering what the wiring looked like for the indicators on the front wing..
Does anyone have any pics on the wiring routing for the indicators on the front wings?
Frank
big_wasa
| posted on 16/3/10 at 05:30 PM |
Ive only seen it done on a zero 7.
Just make it pass the test then use the ones on the scuttle.
What ever way you do it the wire will have to flex for steering and wheel travel. Not ideal long term.
| posted on 16/3/10 at 05:38 PM |
There shouldn't be a need unless things have dramatically changed post SVA.
I just put my front indicators massively forward on stalks so they passed the 45 degrees angle thingy
sebastiaan
| posted on 16/3/10 at 05:50 PM |
My front wheel speed sensor wiring is fixed to the brake flexi (which is covered by a long spring itself). But that's probably a no-no for IVA?
cd.thomson
| posted on 16/3/10 at 05:53 PM |
unfortunately they have ben, fyi frank Nottingham VOSA will no longer pass a se7en type car unless its indicators are on the REAR wings.
Craig
Daddylonglegs
| posted on 16/3/10 at 08:12 PM |
I think he's refering to the side repeaters?
If I'm wrong then I'm off
