austin man
| posted on 16/3/10 at 10:39 PM |
EDIS 4
Going to be running megajolt and EDIS 4 can I drive a rev counter from the EDIS unit ??
FrankP
| posted on 16/3/10 at 10:47 PM |
Yes, i think you can
LINK
paulf
| posted on 16/3/10 at 10:50 PM |
Yes dependent on what make rev counter.
The megajolt has an output that should drive a rev counter or alternatively you can use the rev counter output from the Edis but may need to add a pin
to the connector plug as not all of them have the connection.
The other alternative is to connect it to the pip signal from the Edis , this worked on mine to drive a smiths rev counter that the other methods did
not.
Paul.
austin man
| posted on 16/3/10 at 11:05 PM |
I have fitted an acewell speedo with rev counter but also an additional clock so was looking to drive both and felt that I I could drive on from EDIS
and 1 from MS I would
dhutch
| posted on 16/3/10 at 11:27 PM |
Yeah, there is a tacho out on both the EDIS and the MJLT, i used the one of the MJLT as its was easier to cable up at the time but they *should* both
give the same result.
- Ditto, as said, i proberbly should pick up from the pip as well. All of them give a pulse per rev.
Daniel
jonesier1
| posted on 17/3/10 at 07:37 AM |
yep pin 11 .
im in my own little world...its ok though they know me there
Danozeman
| posted on 17/3/10 at 08:27 AM |
Yep my acewell is driven from pin 11 but it goes mad at 6k which i think is pretty standard.
[Edited on 17/3/10 by Danozeman]
Dan
whitestu
| posted on 17/3/10 at 09:02 AM |
The Acewell will work perfectly of one of the connections to the coil pack. Mine wouldn't work properly off the MJ or the Edis tacho pin.
Stu
