Irony
| posted on 19/3/10 at 12:52 PM |
Gauges for A RV8
Just considering different options for the gauges on my Rover V8. What type of gauges have you guys used and had good experience with? What would be
some good options for me?
I may not be good a engine rebuilding but my fabrication of things like dashboards is pretty good. Would it be possible for me to take a LR defender
instruments pod and tear it apart putting in new faces/surrounds etc? What are the flashy plasma gauges that you see on ebay like (assuming I want a
knightrider cockpit)?
I fancy proper dial gauges and not a LCD instrument pod that some people seem to like.
[Edited on 19/3/10 by Irony]
craig1410
| posted on 19/3/10 at 01:12 PM |
I used the oil pressure and temperature gauge from a Rover SD1 although I would say that the better option is to go for aftermarket gauges with their
own senders. I just had the SD1 gauges to hand and wanted to make a simple "SVA friendly" dashboard initially with the intention of
revising it later.
For the other instruments I went with an Acewell digital dash which handles speed (until my magnets flew off) and RPM (not very well due to pick up
sensing issues. I think later Acewell units work better with the V8 but mine can't do the "revs = sparks / 4" which I need in order
to sense at the coil low tension connection so I have to use a coil of wire around the spark plug lead instead in "rpm = sparks * 2" mode.
This is very erratic despite trying all sorts of tweaks.
Finally, I have a "bright 6" module for indicator lights.
I hope this helps,
Craig.
| posted on 19/3/10 at 02:23 PM |
Try McGill Motorsports on ebay
Paul (Notts)
| posted on 19/3/10 at 06:50 PM |
Never got round to fitting an oil pressure gauge. run for two years now without knowing about any oil pressure problems so hope there arnt any.
water temp gauge does not work and fuel gauge reads half full when the tank is empty.!!!
Paul
kenton
| posted on 19/3/10 at 08:11 PM |
I used revotec, had a good offer at one of the shows while i was building. rev counter and speedo in 100mm, oil, water and fuel abuut 40mm i think.
kenton
robinj66
| posted on 19/3/10 at 10:36 PM |
ETB gauges are good and work well - esp the elec speedo.
ETB
Separate clocks are not cheap though
