jabbahutt
posted on 19/3/10 at 05:46 PM |
indicator sounder
Evening all
Well I'm stumped as usual on the electrics. I temp wired a sounder across the flasher relay pins 31(earth) & 49a(indicator switch) the 3rd
pin is 49(positive)
ignition off and hazards on the lights flash and the tone alternates with the lights, fantastic i thought I've cracked it.
However turn the iginition on and the sounder warbles at about 3 times normal flash speed even though the indicator stalk is in the off position.
so how do I get round the warble when the ignition is on and the indicators are off? is there an easy solution?
please help as i thought I'd actually sussed it on my own, should of known better
cheers
tegwin
| posted on 19/3/10 at 05:50 PM |
IMHO... I would join the left and right hand indicatorw wires together with 2 diodes and run that through the buzzer to ground...
www.verticalhorizonsmedia.tv
ReMan
| posted on 19/3/10 at 05:59 PM |
[img]http://www.tr-register.co.uk/forums/index.php?app=core&module=attach§ion=attach&attach_rel_module=post&attach_id=5776?s=9e16d
88d7910a691f469d35c8aa1e631[/img]
A bit like this
ken555
| posted on 19/3/10 at 08:55 PM |
And "earth" the buzzer via your brake lights, after the switch.
This means when you are sitting waiting at the lights, foot on brake, it doesn't beep all the time.
Or if you feel fancy try the attached diagram
[Edited on 19-3-10 by ken555]
jabbahutt
| posted on 22/3/10 at 07:46 AM |
many thanks for your ideas, must admita lot of it went over my head. It's sorted now as I have a buld on the dash for left and right. I simply
bought another sounder and wired one to each bulb removing the need for delving into diodes etc.
Thanks for the help though I appreciate it.
