Author: Subject: Cortina light / wiper stalks wiring
madrallysport
posted on 23/3/10 at 12:42 PM Reply With Quote
Guys wiring up my dads spartan kit car with a premier loom. I'm after the pin outs / wire colours for cortina stalks any help would be great.
Thanks in advance
Davy
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
robinj66
posted on 23/3/10 at 09:54 PM Reply With Quote
It's probably not much help but my haynes manual shows the following for a Mark 4 2.3 car :
LIGHTING SWITCH
Pins 15 & 30 - red wire --- battery positive
Pins 58 & 55 (a)– grey/black wire --- fused live
MULTI FUNCTION SWITCH (HORN & INDICATORS
Pin 56b – brown(?)/yellow wire --- fused live
Pin L - black/white --- indicator bulb (l/h/s)
Pin R – black/green --- solder joint --- hazard switch + indicator bulb + instrument cluster + earth
Pin H – red --- hazard switch + fuse live
Pin H – red/grey --- horn
Pin 49a – black/white/green --- flasher unit
If you pm me an Email I will try and scan the diagrams for you. At some stage I will also check the wiring on my cobra but that will probably be at the weekend
madrallysport
posted on 24/3/10 at 08:43 AM Reply With Quote
Cheers Robin thats a big help
