Author: Subject: Discreet cut off switch?
flak monkey
posted on 31/3/10 at 05:32 PM Reply With Quote
I am going to have to put a cut off switch on the main loom live feed now I have a tiny battery otherwise its going to go flat rather quick!
I would rather not put a FIA style one on as I want to tuck it away somewhere.
Anyone seen or using anything suitable?
TIA
Sera
http://www.motosera.com
bi22le
posted on 31/3/10 at 05:37 PM Reply With Quote
Why not have both?
It will have the fast finered scum confused and means you can have the 'focused track car' look without comprimising security. Also unless you relay you need a high current switch.
When I worked as an autoelectrician I fitted loads of hidden switches in all kinds of places. Some of them were ones that James Bond would be proud of!
In kit cars people seem to normally fit a basic toggle switch on ignition or fuel.
HTH
Please read my ring story:
goaty
posted on 31/3/10 at 05:38 PM Reply With Quote
i just have a hidden toggle on my landy but that just lets you turn the fuel stop on and off, sure you could do something similar on your car....
i am def planing to aswell but with a kill switch still...
Humbug
posted on 31/3/10 at 05:40 PM Reply With Quote
On my first kit car (1990 Westfield SE) the builder had fitted a toggle switch not-too-obvious place accessible from the driving seat which cut off the fuel pump. Should stop the opportunists, anyway
jacko
posted on 31/3/10 at 05:41 PM Reply With Quote
On new buses they only have a rocker switch as a main switch on the dash 24 v
Guess what i have
[Edited on 31/3/10 by jacko]
blakep82
posted on 31/3/10 at 05:43 PM Reply With Quote
Guess what i have
don't busses have any kind of keyes then?
________________________
jacko
posted on 31/3/10 at 05:45 PM Reply With Quote
Guess what i have
NO keys just nob's and switches
Coaches have keys
flak monkey
posted on 31/3/10 at 06:32 PM Reply With Quote
I dont need it for security, the cars got a thatcham immobilser to deal with that
Just wanted something other than an FIA master switch to completely cut off the main battery power to the loom to prevent battery drain...
It only needs to handle around 40amps max.
Sera
trextr7monkey
posted on 31/3/10 at 07:29 PM Reply With Quote
We have a cut off switch under the bonnet but on the dash there is a tiny rocker switch which runs electric fuel pump.
Rather cunningly a 2 speed heater switch handles the usual ignition key switch circuits, there's a push button start button which is an anonymous harmless looking push button.
The ignition lock is still in position with steering lock pin removed just to confuse the unwary and to give somewhere to hang the keys.
hth
Mike
owelly
posted on 31/3/10 at 08:22 PM Reply With Quote
One of those proximity switches from CPC powering a fat relay. Then there's just the proxy coil to hide. You could hide it under your seat so when you sit in the car with the card in your back pocket, the car will run...........
Shhhhhhwitch.
ETA linky...
[Edited on 31/3/10 by owelly]
http://www.ppcmag.co.uk
40inches
posted on 31/3/10 at 08:23 PM Reply With Quote
How about VWP part number:60520 Security battery isolator switch
adithorp
posted on 31/3/10 at 08:40 PM Reply With Quote
Durite do some battery cut off,/isolator switches (Lucas used to as well). Most are a twist knob to make/break and some are twist to make, hit to break.
adrian
http://jpsc.org.uk/forum/
ReMan
posted on 31/3/10 at 08:48 PM Reply With Quote
TIA
Sporry I don't understand why it shouild go flat?
What's draining it when not in use?
iank
posted on 31/3/10 at 09:04 PM Reply With Quote
Whatever switch you like and a 50A relay would seem the obvious solution.
Anonymous
steve m
posted on 31/3/10 at 10:48 PM Reply With Quote
So if you want to isolate the battery to avoid it draining, whats powering the thatcham approved security device ??
