Author: Subject: Pic's wanted
scutter
posted on 3/4/10 at 12:52 PM Reply With Quote
Pic's wanted
Can you all post up photo's of your fuse boxes? More interested in under scuttle installations, but all welcome. I want to change mine from engine bay, but am open minded
I'll start with my old set up.
from front
from front
ATB Dan.
Steve Hignett
posted on 3/4/10 at 01:05 PM Reply With Quote
RichardK
posted on 3/4/10 at 02:03 PM Reply With Quote
Its just a small fuse box to the right of the expansion bottle
Gallery updated 11/01/2011
robocog
posted on 3/4/10 at 02:14 PM Reply With Quote
I'd keep em under there as they are easy to see at a glance and get to when its dark/wet and snotty...which is when they are most likely to be needed to be got at
Fitted the extra fuses for EFI related gubbins under the dash (other side of bulkhead) and its a bitch to get to and requires a small childs hands to actually remove/replace fuses without getting caught up in the jungle under there...
mind you the wiring under my dash is not the neatest and have been talking about tidying it up for over 3 years now..
The fuses for the EFI stuff will be going other side in engine bay (where yours currently are) when I do eventually get round to it
Too shy to show the under bonnet clutter/mess and bodges photos
Regards
Rob
[Edited on 3/4/10 by robocog]
Mark G
posted on 3/4/10 at 03:53 PM Reply With Quote
This is mine, about 1/2 wired up at this stage but you get the idea.
RK
I like them where they are. Mine are under the dash, mounted on the inside of the firewall, and a pain to get to. Was thinking of moving them to the outside.
rgrs
posted on 3/4/10 at 05:45 PM Reply With Quote
Here's Mine.
Roger
wiring1
wiring1
[Edited on 3/4/10 by rgrs]
afj
posted on 3/4/10 at 06:05 PM Reply With Quote
eerrrrrrrrrrrrrrrr
scutter
posted on 3/4/10 at 10:00 PM Reply With Quote
Cheers folks, I was after a cleaner look in the engine bay, but that seems to most logical placement.
ATB Dan.
omega 24 v6
posted on 3/4/10 at 11:30 PM Reply With Quote
Have look in my archive. I have mine under the dash/scuttle. But it is a hand made loom.
Here
here
here
here
