blakep82
posted on 3/4/10 at 11:00 PM |
linear actuators (i think)
any idea where i might find something like this?
it would need to pull down when no electric is applied, and realese or extend when 12v is applied.
i'm sure there is something out there to do this.
if it can fit into the handbrake able bit of a sierra caliper then it would make a good electric handbrake, but it would need to pull in when no
electric is applied to make it work
anyone seen anything?
________________________
macspeedy
posted on 3/4/10 at 11:15 PM |
theres gate accuators or sat dish accuators
blakep82
posted on 3/4/10 at 11:23 PM |
interesting
will have a look. there must be something out there the perfect size for the job
cheers
dave r
posted on 4/4/10 at 07:31 AM |
what are you trying to do ??
posted on 4/4/10 at 09:48 AM |
Think about the kind of forces you would need to apply, with no current present. This would need an enormous spring, and this arrangement would mean
any fault condition would apply the handbrake on full, not great if you happen to be on a motorway at the time.
If you must use a electric handbrake (poxy things IMO) then I'd suggest you use an OEM actuator and cables, but I'd certainly recommend
you go for a traditional manual handbrake.
blakep82
posted on 4/4/10 at 11:00 AM |
fair enough, was just a hungover idea i had.
prawnabie
posted on 4/4/10 at 11:04 AM |
Most oem systems use a worm gear so that when the cables are wound in nothing can unwind them
blakep82
posted on 4/4/10 at 12:11 PM |
don't busses have pneumatic systems that use air to hold the brakes off?
i probably will go with normal cables, but thats far from ideal too. this chassis wasn't designed for handbrakes lol
Duncan Mould
posted on 4/4/10 at 12:37 PM |
probably in a door lock mechanism, drivers door as the others are only actuators. I am sure that this system is present on central locking systems
indykid
posted on 4/4/10 at 02:09 PM |
the actuaution force required for a handbrake and for a door lock are far from simliar
i'd look at a proper linear actuator using a screw, but it will need power to activate and deactivate.
canibalise one off a scenic
tom
Benzine
posted on 4/4/10 at 02:16 PM |
HTH! XD
oh and you spelt actuator wrong, it's 'actu8r' m8
The mental gymnastics a landlord will employ to justify immoral actions is clinically fascinating. Just because something is legal doesn't make
it moral.
jacko
posted on 4/4/10 at 05:27 PM |
Don't know if it would work but how about a servo off a starter motor
Bus brakes have about 80psi air to make them work
speedyxjs
posted on 4/4/10 at 05:29 PM |
Thats an interesting idea Blake. Would suit my car perfectly too!
