Author: Subject: £25 pair plastic h/lights -have you got?
Mike McKinstry
posted on 6/5/04 at 09:46 PM Reply With Quote
Hi,bought these from I think Premier last year at show.Black plastic shell with side light holder and h4 bulb-marked up.However I have just been to MOT and apparantly beams are partly like a left hand drive beam with a small hi triangle being produced to the right of the beam.Suggestions to move bulb holder etc but has anyone else come across this problem and how to fix????Was mot failure!!Mike.
posted on 6/5/04 at 09:47 PM Reply With Quote
see bobs comments in his sva date thread, mk section. i think his black plastic ones failed the main test.
theconrodkid
posted on 7/5/04 at 06:43 AM Reply With Quote
i got them,if you turn the reflecter/lense a few degrees either way the patern comes out right
who cares who wins
pass the pork pies
posted on 7/5/04 at 08:39 AM Reply With Quote
Me too.
Turned the glass about 10mm and they passed.
posted on 7/5/04 at 04:14 PM Reply With Quote
First check the bulb holders aren't universal LHD-RHD ones that are have a little plasic slide that allows the bulb to be roatated by 15 degrees in a clockwise direction when viewed from behind the reflector to give the correct beam pattern for the uk
