Alan M
posted on 15/4/10 at 01:35 PM |
E Tech mirror wiring
I've just bought some mirrors from Europa with built in LED side repeaters. These have 3 wires coming out and the following instructions:
Blue, connect to (+) packing lamp
White, connect to (+) single lamp
Black, connect to (-) vehtcle round wire
What does this mean in English??
Confused of warwickshire
richardh
| posted on 15/4/10 at 01:37 PM |
black = earth
try the others one at a time using a connection to the battery
Not good on leccy bits like this either
Time for a change!
Alan M
| posted on 15/4/10 at 01:45 PM |
Yeah. I'd worked out that:
Black, connect to (-) vehicle ground wire
Fiendishly cunning these orientals!
handyandy
| posted on 15/4/10 at 01:56 PM |
you may still need other side repeaters if the ones in the mirrors can,t be seen from the correct angle from the rear, ( mate had same problem on his
cheers
andy
Alan M
| posted on 15/4/10 at 04:05 PM |
"you may still need other side repeaters if the ones in the mirrors can,t be seen from the correct angle from the rear, ( mate had same problem
on his )"
But I've already got SAV
Alan M
| posted on 15/4/10 at 04:06 PM |
Obviously I meant SVA!!!
handyandy
| posted on 15/4/10 at 04:19 PM |
oops sorry,
you,re "sorted" then
i,ll crawl back under my stone
cheers
andy
blakep82
| posted on 15/4/10 at 06:08 PM |
on his )"
are you oriental then? lol
________________________
Mix
| posted on 16/4/10 at 01:37 AM |
Hi
Just a stab in the dark .............
Blue - parking lamp
White - signal lamp
Black - vehicle ground
Regards Mick
