Author: Subject: Ignition coil for a Bosch dizzy
posted on 10/5/04 at 08:03 AM Reply With Quote
If you've seen my thread in the Engine section, you'll know that I've finally got the Bosch electronic distributor working on my X-flow (the dizzy came from a valencia-engined Fiesta).
Now it looks like I will need a different ignition coil as the standard 'points' type isn't suitable.
A few suggestions were made, but the most sensible choice seems to be the coil from a Mk4 Escort. What I need to know is whether this is a ballasted coil (9v) or non-ballasted (12v) - anyone know?
If it is ballasted then I need to fit a ballast resistor - could I run without the startup boost wiring, or would I have problems (I don't feel like mucking around with my loom at this late stage).
cheers,
theconrodkid
posted on 10/5/04 at 09:12 AM Reply With Quote
just ask for an electronic ign coil for a fiesta/escort,they are all the same and not resisted
who cares who wins
pass the pork pies
SeaBass
posted on 10/5/04 at 12:29 PM Reply With Quote
Not ballasted,
this is described as a BOSCH TCI coil...
JC
posted on 10/5/04 at 02:26 PM Reply With Quote
Ta muchly!
An order has been placed in my local auto parts emporium... (too lazy/not enough time to go to the scrappy).
