Author: Subject: DPDT on-off-on momentary switch polarity reverse, where to buy
nitram38
posted on 21/4/10 at 08:44 PM Reply With Quote
For my up and coming coilover hydraulic lift on the motaleira and possible supplying kits, I need to source a supply of these switches. (they need to switch over 22.5A)
The only place I've found them is in the usa.
I also want them to have the cross over built in. I don't want to spend more time making links.
se7en
posted on 21/4/10 at 10:26 PM Reply With Quote
Maplin should have something that would suit.
I found this switch which has the benefit of being waterproof.
http://maplin.co.uk/Module.aspx?ModuleNo=98092
Hope this helps
Tom
nitram38
posted on 22/4/10 at 05:01 AM Reply With Quote
I've looked at all the usual suspects, maplin, RS, CPC Farnell, CBSonline.
None of them have the cross over links.
As I want to sell them in kits, I don't really want to soldering wires for people, besides that it looks more professional
Benzine
posted on 22/4/10 at 06:16 AM Reply With Quote
I recently bought some from 'rapidonline' .com or .co.uk. I don't know if they do any with the crossover
rgrs
posted on 22/4/10 at 07:20 AM Reply With Quote
Have you considered lower rated switches with control relays?
Would give far more options.
Roger
mad4x4
posted on 22/4/10 at 08:35 AM Reply With Quote
What about a relay on a small PCB and a smaller rated switch. Could do that for about £5 a board I guess all in or even less if you bulk order
Circuit Layout would be simple to do. you could even get fancy and put on 2 led's - Normal & Reverse.
Scot's do it better in Kilts.
nitram38
posted on 22/4/10 at 01:59 PM Reply With Quote
Kiss, keep it simple!
Less parts, less to go wrong.
