Author: Subject: Megasquirt Cooling Fan Option
Bumble
posted on 22/4/10 at 11:24 AM Reply With Quote
Hi all,
I have the MS option installed to control the rad cooling fan. I fancy the idea of an override switch but not sure how to wire this in. Any suggestions please?
Thanks,
Matt
flak monkey
posted on 22/4/10 at 11:34 AM Reply With Quote
Just wire in the switch to switch the relay to ground.
You should have MS controlling a relay, switching it to ground when the fan comes on. Run another wire from the switched ground on the relay to your override switch, then the other side of the switch to your chassis.
Hey presto, fan override
I have mine wired up this way and it works fine.
Sera
http://www.motosera.com
Bumble
posted on 22/4/10 at 12:25 PM Reply With Quote
Cheers David,
So in the attached pic, run another wire from terminal 56 on relay to one side of override switch other side to earth?
If so, very simple.
Thanks,
Matt
flak monkey
posted on 22/4/10 at 12:26 PM Reply With Quote
Yep, simple as that
Sera
Bumble
posted on 22/4/10 at 12:33 PM Reply With Quote
Thanks.
ChrisW
posted on 22/4/10 at 01:46 PM Reply With Quote
You shouldn't need an override if you have the temp values in the MS set up correctly!
Chris
Bumble
posted on 23/4/10 at 12:44 PM Reply With Quote
Chris
^^^For sure, but you never know when you might need it so I'd rather put one in and hopefully never have to use it!
Thanks,
Matt
posted on 23/4/10 at 01:20 PM Reply With Quote
Does the MS option work after the ignition is switched off?
ATM I'm using the rad switch which has a permanent live and doesn't go off until its cool enough...
It's got a relay as well, need to have a look at the Haynes, I'm confused now.....
Bumble
posted on 23/4/10 at 01:30 PM Reply With Quote
Coozer.....no it will not operate with ignition off.
posted on 23/4/10 at 01:52 PM Reply With Quote
Ok, back to original plan then.
