Author: Subject: electric reverse...an adaption??
boggle
posted on 23/4/10 at 03:08 PM Reply With Quote
im just having a thought....
600 pounds for a reverse box is not an option at the moment, so im looking at using a starter motor....
however, i dont want to run this on the bike battery so could i fit a small alternator to run off the rear diff flange to charge a seperate battery???
cheers
barry
[Edited on 23/4/10 by boggle]
u2u me for details
mangogrooveworkshop
posted on 23/4/10 at 03:14 PM Reply With Quote
Space is at a premuim so stickin more stuff under the rear is a no no.
Cant you hire borrow one of some one...just for the test...same as the catz
the usual way is to stick a motorcycle starter motor on a cog at the top of the rear tunnel.
that will require a small jap battery to run it.
Using a bike battery is a poor move as we have found. The first time you lay the car up for a few weeks you need a new 50 quid battery.......
boggle
posted on 23/4/10 at 03:17 PM Reply With Quote
car is allready legal...i need a reverse for hillclimbs and the misses......
u2u me for details
Dangle_kt
posted on 23/4/10 at 04:01 PM Reply With Quote
Originally posted by boggle
car is allready legal...i need a reverse for ... the misses......
Just make sure you don't miss when you drive at her, then you won't need reverse to get her.
40inches
posted on 23/4/10 at 04:45 PM Reply With Quote
Fit a split charge relay, then the two batteries are kept charged but are on seperate circuits
MakeEverything
posted on 23/4/10 at 11:32 PM Reply With Quote
Get a proper engine you Jessy.
Kindest Regards,
Richard.
