norfolkluego
| posted on 23/4/10 at 05:31 PM |
Fireblade fuel pump
My new pump has arrived to replace the Facet and Filter King, simple enough, inlet and outlet plus two wires, wires are solid green and a blue/black
one, anyone hazzard a guess which is earth, which is live (incidentally it's got Mitsubishi badges on it not Honda)
[Edited on 23/4/10 by norfolkluego]
tomprescott
| posted on 23/4/10 at 05:35 PM |
Loads of japanese stuff is mitsibushi branded - nissan, honda, yamaha, its still oem so I wouldn't worry about that.
Not sure about the wires though, wish I could help....
A bird in the hand....
JF
| posted on 23/4/10 at 05:38 PM |
Solid green is ground on Honda bikes and black with all sort of colors for live. And yes these Honda bikes are fitted with Mitsubishi pumps.
[Edited on 23/4/10 by JF]
tomprescott
| posted on 23/4/10 at 05:42 PM |
There yo go, snorted!
koiking125
| posted on 23/4/10 at 05:52 PM |
Where did you get your new pump from and how much?? Terry Rudd Honda in Holbeach quoted me £154.75 + VAT
MK Owners Club Member (Frosty) No.1159
norfolkluego
| posted on 23/4/10 at 07:50 PM |
David Silver Spares of Leiston
Pump was £89, including pump, postage and VAT, total bill was £110.81, I can give you their tel. number/website etc if you want
norfolkluego
| posted on 23/4/10 at 07:53 PM |
What's this bit, looks as if it's lipped for another hose
koiking125
| posted on 23/4/10 at 08:02 PM |
Was it from an RRN 1992 blade? Think I have found it "linky"
norfolkluego
| posted on 23/4/10 at 09:21 PM |
I left the ordering to my son who is a biker so knows more about them than I do, apparently the pumps were common across all the early Fireblades
apparently, 92-98 I think he said
koiking125
| posted on 23/4/10 at 09:27 PM |
Thanks, thats saved me a few quid..
JF
| posted on 23/4/10 at 09:45 PM |
That bit is for a drainage hose, a breather. simply put some siliconhose or similar (6mm iirc) to stop water getting to the electrical bits. But alow
condensation drain out. On the bike the pump is mounted just below the tank with I estimate about 20cm of hose hanging down. As you will probably have
it at the botom of the car I'd just ziptie a similar length to a chassis member slightly downward from the pump.
norfolkluego
| posted on 23/4/10 at 10:07 PM |
Anybody ?
I've got my inlet and outlet on the top of the pump, what is the small one at the bottom for
norfolkluego
| posted on 23/4/10 at 10:11 PM |
Thanks JF, hadn't seen your post before I asked again
JF
ehm... didn't you read my post...
