omega0684
posted on 24/4/10 at 01:28 PM |
battery Again: this one any good?
battery linky
Dangle_kt
posted on 24/4/10 at 01:40 PM |
expensive for a no name - get a good make if you can.
Andy Bates sells good ones that are lightweight but good qaulity and reasonable price.
That is essentially a motorbike battery - but a cheapo one.
richardh
looks good
Time for a change!
daniel mason
posted on 24/4/10 at 01:53 PM |
you not fancy one of the ones recomended by nigel dean in kit car mag? cant remember the name of them off hand,but they looked quality!
omega0684
posted on 24/4/10 at 02:33 PM |
i dont get the kit car mag, do you have a copy that you can dig a name out from?
Confused but excited.
posted on 24/4/10 at 02:36 PM |
"THIS IS A HUGE 10KG LIGHTER(approx) THAN A STANDARD 43AH BATTERY & AROUND 1/2 THE SIZE."
No sh1t Sherlock. That's probably because it is only a 20AH battery!
big-vee-twin
posted on 24/4/10 at 05:02 PM |
I've just fitted one like that to my motorbike, it does have a 1600 engine, so I would imagine it would be ok for a small car engine.
But I would say if the car engine takes a few times to start it would flatten pretty quick if you have an engine which is a good starter should be ok.
If its a tempremental starter I would go for something with more Amp hours.
http://www.triangleltd.com
bimbleuk
posted on 24/4/10 at 06:24 PM |
I've been using standard 19Ah bike batteries for several years. Actually the last one has only just failed after 4 years use.
That was with a 1.6 4AGE with quite high CR at 11:1. No you can't expect it to continually crank the engine but I had a decent ECU and map so
starting was quick.
40inches
posted on 24/4/10 at 07:35 PM |
It's the RMD Rally Design one.Here
posted on 24/4/10 at 07:40 PM |
Very dubious --- No way believe the claim for cold cranking current of 680 amps, to get that sort of cold cranking current you need a very
large heavy duty battery as normally found in a 2 litre diesel.
If you want a small light battery a type 054 as fitted to some small Japanese vehicles inlcuding the Suzuki Carry 10kg 35 amp hours 340 Cold
Cranking Amps SAE.
posted on 24/4/10 at 08:39 PM |
I agree, even the very expensive Odyssey or Varley batteries with the spiral plates can't achieve even half that CCA in the equivalent
capacity.
I suspect it's an absorbed glass mat motorbike battery to be honest.
scooby_doo_do
posted on 28/4/10 at 07:31 PM |
i know this may be a bit of overkill and too big, but i have a nearly new PB gel racing battery http://www.tripkings.co.uk/stuff/large/0020.jpg
I used it in my Ultima Spyder as i thought the red top 40 was dead.. only to find it was the starter motor.
It's the same size as a varley red top but more powerfull.
Craig.
Westfield 2.0 XE Redtop
