clairetoo
| posted on 30/4/10 at 09:41 AM |
I just released the magic smoke
I'm sitting here feeling totally gutted............been working flat out for the last two weeks to get another V6 Fury to Stoneleigh , even got
the MOT booked for this afternoon .
Right in the middle of fitting the dashboard , connected up the fog light switch - and as soon as it was switched on , the fuse popped .
So I put in a larger fuse.............and out came the smoke
There is loads of melted wiring behind the dash now
There is no way I can re-wire it in time , and I dont have a clue where the fault might be - so today is now a total write off
Its cuz I is blond , innit
Claire xx
Will weld for food......
flak monkey
| posted on 30/4/10 at 09:49 AM |
Bugger
Hate it when that happens
If I was closer I would come and give you a hand to sort it.
In hindsight, never fit a fuse with higher capacity than the cable - that's what they are for...
Sera
http://www.motosera.com
l0rd
| posted on 30/4/10 at 09:50 AM |
| posted on 30/4/10 at 09:51 AM |
Do you need any cable Claire? Just filled the boot with some, can bring to Stoneleigh...
Ty-wraps too, the ones with te clips for attaching to holes in body's, hundreds, all sizes.
What do you need?
clairetoo
| posted on 30/4/10 at 09:56 AM |
What do you need?
I need someone to take the car away , and bring it back working...............I hate wiring , when I first fitted the loom it took me three months to
find a small fault (instructions didnt agree with the colours , which didnt match Ford colours , it's a premier wiring loom )
Claire xx
boggle
| posted on 30/4/10 at 09:58 AM |
have you spoke to eddie99....he is a loom genius.....
u2u me for details
| posted on 30/4/10 at 10:00 AM |
Wiring is a doddle, easy for me to say cause I find it dead easy... and work for a harness manufacturer....
Body work and cosmetics for me (you'll see what I mean when you see my car) are a nightmare to me...
I considered restoring an Escort or something but the thought of all that bodywork rust made me want to top meself!
Chin up!
Note to self: My car is still in bits but I WILL be setting of at 10am in the morning
clairetoo
| posted on 30/4/10 at 10:05 AM |
Biggest problem is - a new loom wont help as I would then have to make it fit , and connect it all up - which is where I am lost
Any body know of some one who would come round , measure the car , and supply a loom with all the plugs and connectors allready fitted ?
Claire xx
boggle
does the car start up?
u2u me for details
clairetoo
| posted on 30/4/10 at 10:12 AM |
Yep - it runs , everything was working last night - all I did was remove and re-fit a couple of switch's .
Claire xx
boggle
| posted on 30/4/10 at 10:31 AM |
ok...can you not do a temp re wire for the fog light???
what else is not working?
u2u me for details
flak monkey
| posted on 30/4/10 at 10:34 AM |
Claire, if you want a hand one weekend to do the wiring I can come and help. You arent that far from me in the grand scheme of things.
All you would need to do is order a load of wiring in different colours and connectors to suit and I'll do the rest in a couple of days.
ETA I'll work for sarnies and tea
[Edited on 30/4/10 by flak monkey]
Sera
jossey
| posted on 30/4/10 at 10:55 AM |
sorry to hear your stuck. im a auto electrician but am a little far to help.
i would start at the fog lights and run wiring direct to battery to see if there is faults the work back wards from there.
you can just run more wire down to the fogs and battery and it should pass ok.
this aint too hard to do.
sorry again
dave j
David Johnson
Bumble
| posted on 30/4/10 at 11:16 AM |
Hi Claire,
Sorry to hear of your wiring woes....I've nearly finished wiring my car using a Premier Loom and whilst the quality of the loom is good and Alan
is very helpful the instructions are not the clearest and during one of my numerous calls to Alan he remembered he'd run out of Red/Black cable
and some Brown/Black and used different colours instead!! Now wonder I was struggling!!
Hope you get things sorted quickly.
Matt
mangogrooveworkshop
| posted on 30/4/10 at 11:26 AM |
I hate wiring ....and the worse bit is that is what my day job is....Smoke pipes
mookaloid
| posted on 30/4/10 at 11:57 AM |
mucho sympathy
big_wasa
| posted on 30/4/10 at 12:40 PM |
Hmm I love wiring, I just wish I had half your enginering skills.
