eznfrank
posted on 30/4/10 at 01:41 PM |
COuld someone possibly confirm some lighting wiring colours?
My headlamps didn't come with a wiring diagram so I called the supplier and they advised me the colours were:
Red - Main beam
Green - Dip beam
Blue - Side lamps
Black - Earth
I also could do with knowing the rear/stop light colours, I have green, red and black.
Based on the above I would have thought it would be
Black - Earth
Green - Brake light
Red - rear light
But that sounds wrong?
GRRRRRR - I took today off work to spend in the garage and seem to have got sod all done!!
deezee
posted on 30/4/10 at 01:43 PM |
Couldn't you just connect a 12v battery to the lamps to confirm this yourself. That what I did when I got mu 2nd hand lights. Took 5 mins.
posted on 30/4/10 at 01:45 PM |
GRRRRR, I've spent the day in the office doing bot all while I NEED to be in garage! 14 mins and counting....
Who supplied the loom?
omega0684
posted on 30/4/10 at 02:00 PM |
on my vicky green loom
main beam - blue with white line
dipped - blue with red line
12v supply to side - red
earths - black
don't think that helps though
Hugh_
posted on 30/4/10 at 03:16 PM |
My rear lights were:
Black - earth
Red - tail light
Black/Green - brake.
eznfrank
The loom is a chopped about zx12 loom which by some feat of magic I have managed to make work in most aspects.
As above I'll have to do a bit of testing I guess, I just haven't got a ful battery at the moment that's all
jase380
posted on 30/4/10 at 04:20 PM |
Im with deezee, find out which is the earth then just put each of the other wires to a 12v supply and see what light comes on
posted on 30/4/10 at 04:25 PM |
earths - black
That is the widely used old Lucas way of doing it.
http://www.expeditionlandrover.info/Lucaswirecode.htm
