turbodisplay
posted on 30/4/10 at 02:20 PM |
I can do CAN
Almost finished testing, but results so far are positive. My CAN to serial converter is finished, just requires a case to be machined up. It will be
able to be reflashed with a new program as required for different ECUs.
I have the CAN protocol for Emerald, if anyone has data on other ecus/ data formats I would be most grateful.
Darren
kipper
posted on 30/4/10 at 02:29 PM |
anything you can do
I wonder what Darren is on about.
Now, about my carbs and points.
Where did that go?
Dusty
posted on 30/4/10 at 04:19 PM |
Points. Pah. Fancy modern rubbish. I need to sort my magneto.
iank
posted on 30/4/10 at 04:25 PM |
magneto, pah devils work. Now off to adjust the balls on my governor valve.
Anonymous
imp paul
posted on 30/4/10 at 04:34 PM |
or its good to use a wibble switch most of the time
